Power Trans switch bad? - JeepForum.com
post #1 of 10 Old 08-09-2013, 05:02 PM Thread Starter
RamboPants
1987 XJ Cherokee
I have been noticing for a while that my jeep slips and stumbles when the transmission is in power mode but when set it to comfort its fine. The light doesn't work on the switch. If the problem is a bad switch why would it half as work when its in power mode?
RamboPants is offline
post #2 of 10 Old 08-09-2013, 09:32 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Do this, after making sure the 7.5 amp "trans" fuse is good in the fusebox.
Bypassing the Power/Comfort Switch on a Renix Jeep
Remove and unplug the switch. In the harness are 3 wires One has a stripe, one is tan, and the other black. Make a 4" jumper wire with a male spade at each end. Plug one end in the cavity for the tan wire and the other in the cavity for the striped wire and you'll be in permanent Power mode. Stuff the harness back in and reinstall the switch for looks.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 10 Old 08-10-2013, 02:43 PM Thread Starter
RamboPants
1987 XJ Cherokee
checked fuse its good, but if the jeep runs bad in power mode why would I want it there permanently?
post #4 of 10 Old 08-10-2013, 02:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just try it.
post #5 of 10 Old 08-10-2013, 02:54 PM Thread Starter
RamboPants
1987 XJ Cherokee
Word!
post #6 of 10 Old 08-10-2013, 04:02 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by RamboPants View Post
Word!
What's that mean?
post #7 of 10 Old 08-10-2013, 04:46 PM Thread Starter
RamboPants
1987 XJ Cherokee
It means Ok I'll try it
post #8 of 10 Old 08-10-2013, 06:07 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm an old fart. Not familiar with this new fangled lingo.
Do you remember Mr Green Jeans?
post #9 of 10 Old 08-12-2013, 09:24 AM Thread Starter
RamboPants
1987 XJ Cherokee
lol no
post #10 of 10 Old 08-12-2013, 03:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
lol no
Elmer Fudd?
