Power steering wanes at warm idle - JeepForum.com
post #1 of 6 Old 01-18-2011, 12:48 PM Thread Starter
ryder267
1992 XJ Cherokee
1992 Laredo 4.0L
I start up my Jeep after sitting overnight and the power steering works fine. I can turn the wheels both directions with ease as the Jeep sits at idle.
After I start driving for a bit, and the engine gets warmed up, the power steering fails if I try to turn the wheels while stopped at idle.
If the Jeep is in motion, or if I raise the RPMs while sitting, the power steering works fine.
Hopefully, I'd like to diagnose this problem before I start throwing parts at it.
Any thoughts?
Cheers -John
ryder267 is offline
post #2 of 6 Old 01-18-2011, 12:56 PM
danw77
1994 ZJ
have you checked to fluid level? any leaks?
1983 CJ7 & 1998 ZJ
Hello, my name is Dan, and I have a Jeep problem.
danw77 is offline
post #3 of 6 Old 01-18-2011, 01:34 PM Thread Starter
ryder267
1992 XJ Cherokee
Fluid level good, no leaks.
ryder267 is offline
post #4 of 6 Old 01-18-2011, 02:44 PM
danw77
1994 ZJ
check the belt. if it's not low on fluid, a loose or worn belt would be my next guess.
1983 CJ7 & 1998 ZJ
danw77 is offline
post #5 of 6 Old 01-18-2011, 03:26 PM Thread Starter
ryder267
1992 XJ Cherokee
Belt is taut and is not slipping.
I think it's the pump, but want a second opinion. Has anyone faced this, or a similar problem before?
ryder267 is offline
post #6 of 6 Old 01-18-2011, 04:06 PM
danw77
1994 ZJ
i really don't think it's the pump. is it making any noise? is there any play in the pulley? these are typical signs that the pump is going out (also, leaks but you said there were none). i find it hard to believe that if the pump were going out would be getting symptoms you are describing. maybe someone will chime in with some additional advice, but i'm still putting my money on a loose or glazed belt. they need to be really tight in an XJ.
1983 CJ7 & 1998 ZJ
danw77 is offline
Knock at idle after brief warm up Fury3 XJ Cherokee Technical Forum 6 11-05-2010 06:00 AM
high idle when warm 97tjeff XJ Cherokee Technical Forum 2 05-11-2010 01:56 PM
Idle RPM while engine is warm? abrouwers XJ Cherokee Technical Forum 6 03-02-2010 06:35 PM
