Quantcast power steering problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > power steering problem
Old 07-31-2008, 08:10 AM   #1
twobit
I got no answers in the general jeep discussion area so I'll ask it here...
__________________________________________________ _________
Yes I used search function but did not find answer......
Cherokee is a daily driver with 168,000 highway miles. It has been babied.
Here's the problem ... happens a couple of times a month: after about 40 miles at 60 MPH on a highway we slow to make a right turn onto a side road and power steering goes super stiff a few seconds, making it really hard to make the turn. I've siphoned out the old fluid, replaced with new fluid, no change in symptom. Belt is OK and pump makes no noise at all. No leaks. Steering stabilizer shows a little oil leak. Other than these "moments" the power steering is fine. This is an intermittent problem, always after 45 minutes of highway travel, then as we turn off to the right. It happens about every tenth time we make these turns off the highway onto our side road. Never had it do it in city driving or any left turns (but we dont make left turns off the highway, so that has never been tested). Both myself and my wife have experienced this a few times. It has been doing this about six months on and off. Slow parking lot steering is never a problem.
Is the pump going bad or is the steering box going bad?
Was hoping that someone has had similar symptoms before I start throwing parts at it. Oh, no steering related parts have ever been replaced. We have owned it since mile 1. I'm ready to buy a new pump for it, but was hoping for comment as to the fix.
06 Solar Yellow TJ X obtained 10-2009 with 3400 miles
99 Cherokee Sport, bought new, now @ 223,000 miles
Southwest Texas
twobit is offline   Reply With Quote
Old 08-11-2008, 11:07 AM   #2
Blurple
Originally Posted by twobit View Post
... we slow to make a right turn onto a side road and power steering goes super stiff a few seconds, making it really hard to make the turn.
This just happened to me! Not cool. Anyone else have this issue that knows a solution?
Blurple is offline   Reply With Quote
Old 08-11-2008, 04:43 PM   #3
AZ Jeff
I am guessing the issue is in the spool valve inside the steering gear itself. The fix, of course, is new/reman/used replacement steering gearbox.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Glock Forum
