Quantcast power steering problem... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > power steering problem...
Old 09-23-2003, 09:37 PM   #1
4X4&2xAsThick
Think the power steering is failing... much harder to turn, squeal while turning and poor response. Question is... how hard is it to replace the pump and is there any other part that might be causing this? Is there just the pump or is there another part to be replaced that I don't know about?
1990 Cherokee Limited
It has tires and an engine!
It is red!
4X4&2xAsThick is offline   Reply With Quote
Old 09-24-2003, 09:57 AM   #2
ddoffroad
That sounds like it is most likly your steering pump, but there is also the steering gear box which can cause problems. The first thing you should do is flush the PS resivour and put in brand new fluid and also add some PS sealer. If that does not seem to help then your pump is most likely fried. I have not replaced one myself but I hear they are difficult. I did however replace by gear box which is not too difficult of the bolts come out.
99 XJ - 4.0L HO, Rusty's K&N Intake, Rusty's 4.5" full suspension, 31x11.50 Swamper LTB's, 15x8 blk Daytona's, clear lenses, Warrior bumper w/ hooks
Down & Dirty Offroad: http://ddoffroad.com/
My XJ site: http://www.cardomain.com/ride/2488225/
My Old XJ Site: http://www.cardomain.com/ride/2058746
ddoffroad is offline   Reply With Quote
Glock Forum
