#1 | |
power steering problem
will a 89's power steering pump fit on a 2000's power steering bracket?
thanks Kevin
#2 |
More than likely yes.
96' XJ 4.0 I6 engine with AFE magnum Intake, Bored out throttle body, TB spacer, 99' Intake swap' Straight pipe with Glass pack , AW4 Trans/Command trac NP 231,Dana 30 front/8.25 rear/27 spline axles,31x10.50 All terrain tires. |
#3 |
It might require some "modifying" IIRC the earlier ones had threads that went through the bracket and into the pump. Later ones the bolts go through the pump and into the bracket. MY 97 engine has threads in the manifold and the bolts go through the bracket, through the holes in the pump housing and then thread into the manifold. Take a look,might take some modification with a drill bit but it should be doable.
01 WJ 06 WK, wife's Jeep ASAT= All Season All Terrain |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
