Power steering leak b/t pump and reservoir - JeepForum.com
post #1 of 4 Old 06-26-2012, 08:41 AM Thread Starter
Wharf Rat
96 XJ 4.0. I have a leak between the power steering pump and the reservoir that leaves about an 6" puddle every night. I have searched and found no fix, only instructions on how to change the o-ring, which I have done 3 times now. Even tried using two o-rings which slowed the leak but did not stop it. It is a new pump and new reservoir (Advance) which have both been taken back and replaced again becuase I thought it was a faulty desigin, also all new hoses. Still leaking, and I'm sure it is leaking there. Any one else had this issue and what did you do to fix?
Wharf Rat is offline
post #2 of 4 Old 07-18-2012, 02:22 PM
gnic188
You ever find a fix? I am having a similar issue on my 99 classic.
gnic188 is offline
post #3 of 4 Old 07-18-2012, 02:26 PM
KEH1997
When the PS pump in my 4.0 went bad a year or two ago, I initially decided I'd just replace the pump and reuse my existing reservoir. When I went to pick up the pump, the saleswoman at Advance guaranteed me I'd have leaks if I tried reusing the reservior. Once its disconnected from a pump and reinstalled, it's incredibly hard to reseal.
You can try Power Steering Stop Leak fluid, but I doubt it will cure a leak that big. Sorry I don't have any incredible advice...just wanted to say that it's a pretty common issue.
KEH1997 is offline
post #4 of 4 Old 07-18-2012, 05:30 PM Thread Starter
Wharf Rat
Yeah i figure I'm just going to have to take them back and get one that is already put together. They are still under warranty so they should honor it. Thanks.
leak , pump , reservoir , steering
2000 XJ power steering pump leak, what to do? Finallyajeep XJ Cherokee Technical Forum 31 04-08-2012 11:21 AM
How do you get the power steering pump reservoir off? jeepjack1995 XJ Cherokee Technical Forum 5 04-05-2012 09:02 PM
Power Steering Reservoir Leak SoloCamo XJ Cherokee Technical Forum 2 11-17-2008 09:47 PM
power steering pump install - reservoir VR6NH XJ Cherokee Technical Forum 9 02-28-2007 11:56 PM
Power Steering Reservoir Leak impulse XJ Cherokee Technical Forum 8 05-23-2005 10:54 PM
