Power steering fluid temp question... - JeepForum.com
post #1 of 7 Old 06-05-2010, 02:29 AM Thread Starter
sAe23
1995 XJ Cherokee
How hot is too hot for power steering fluid?
I have a PSC gearbox and high output pump.
The mfgr "recommends" installing a cooler, which I have yet to do.
Using an infrared thermometer, I measured the fluid inside the tank at 140 degrees after a 20 minute drive.
Does anyone know the temp specs, or possibly have a way of measuring the temp of their fluid and posting it here??
TIA
Steve
sAe23 is offline
post #2 of 7 Old 06-05-2010, 07:11 AM
postaldave
190 degees
1976 FJ40 aka Yoda Monster
1996 Jeep XJ
Originally Posted by xdgt03 View Post
I removed mine. It is against federal law but so is being an illegal immigrant so...
postaldave is offline
post #3 of 7 Old 06-06-2010, 12:28 AM Thread Starter
sAe23
1995 XJ Cherokee
Originally Posted by postaldave View Post
190 degees
Hmm...
Is that the "too hot" temp, the temp it SHOULD be at, or the temp YOUR fluid runs at??
Steve
sAe23 is offline
post #4 of 7 Old 06-06-2010, 07:57 AM
postaldave
around 190 is when most petros start breaking down so i've heard.
1996 Jeep XJ
post #5 of 7 Old 06-06-2010, 08:11 AM
2005X
TIA
Steve
although i dont know what my temp ran at i do know my PSC system overheated and caused air bubbles causing me to loose all steering until the system cooled down enough. on road driving never had issue, it was all on the trails with the low speed and lack of air movement. this weekend i did get the cooler installed along with hood vents to let the ambient air escape
2005X is offline
post #6 of 7 Old 06-06-2010, 03:43 PM Thread Starter
sAe23
1995 XJ Cherokee
I'd like to hear if the cooler helped with your problem.
Thanks.
Steve
sAe23 is offline
post #7 of 7 Old 06-06-2010, 07:00 PM
2005X
Thanks.
Steve
i will keep ya updated, sucks though cause i have no wheeling trips to give it the real test. so far only on road driving
2005X is offline
no power steering fluid? boondocksaint XJ Cherokee Technical Forum 4 05-27-2010 01:47 PM
Question about Transmission and Power Steering Fluid... Chelsea XJ Cherokee Technical Forum 16 04-12-2010 09:02 PM
what to use for power steering fluid mud-dog27 XJ Cherokee Technical Forum 4 05-15-2009 03:25 AM
Power Steering Noise and Temp. Problem Fiend101 XJ Cherokee Technical Forum 3 11-07-2008 05:34 AM
Power steering fluid... Gr8Swammee XJ Cherokee Technical Forum 3 05-17-2005 03:40 PM
