Power Locks Don't Work, but Power Windows Do?????? - JeepForum.com
post #1 of 5 Old 02-11-2013, 08:47 PM Thread Starter
bkfitz
- 2001 Jeep Cherokee Sport
- Viper Alarm System installed before I owned it
- Power Locks don't work at anymore, from any door or from the viper remote
- The little light on the power locks switch on drivers and passenger door does light up
- No noises or anything when I press lock/unlock switch on any door
- Power windows all work fine, including the window lock.
- Checked the #13 fuse and it looks fine
HELP!
bkfitz is offline
post #2 of 5 Old 02-11-2013, 09:45 PM
Project1
I had some problems like yours... I just went doorless ..take that power locks and windows .. in the trash
Project1 is offline
post #3 of 5 Old 02-12-2013, 11:18 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Drivers door master switch issues are common. Driver door wire harness issues are common. The Viper complicates your troubleshooting, especially if the installer was a moron.
You need to do some investigating and locate the cause of the problem, or eliminate one or more of the most common causes of similar problems.
Grab your volts/ohms multi-meter and test for wire continuity, and for power/ground in the correct places. You may want to unplug or disable the Viper and see if that is the cause.
CJ7-Tim is offline
post #4 of 5 Old 02-12-2013, 11:39 AM Thread Starter
bkfitz
Ugh... where would you start? Take the panel off the door and check the voltage at the master switch?
I don't even know where the Viper 'box' is?
bkfitz is offline
post #5 of 5 Old 02-12-2013, 06:05 PM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by bkfitz View Post
.. where would you start? Take the panel off the door and check the voltage at the master switch ?
Yes.
CJ7-Tim is offline
