Power Draw Problem - JeepForum.com
post #1 of 3 Old 02-14-2011, 05:16 PM Thread Starter
98xj4x4
Power Draw Problem
Alright, this all started when i had replaced my water pump. when i press the window control for the passenger side window, i have a power draw that dims the interior lights and when the motor is running it bogs down the motor as well. The passenger side window only goes down and not up, i checked the window motor and it works fine, i don't know what it could be. Help would be awesome. Thanx
1998 2Dr Cherokee. 4.0 HO with an AX-15 5spd and NP231. 30" AT2'S w/spacers and shackles
98xj4x4 is offline
post #2 of 3 Old 02-15-2011, 03:06 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The water pump replacement is unrelated. You have a short circuit in the door wiring that should be located and fixed before you damage something or cause a fire.
CJ7-Tim is offline
post #3 of 3 Old 02-15-2011, 08:22 AM
severous01
severous01's Avatar
while you're in there clean the window tracks. that's probably causing your 'bog' issue.
clean it with brake cleaner and then lube it with white lithium grease in a spray can with a straw.
severous01 is offline
Power draw from winch. Repair options? mcthnif XJ Cherokee Technical Forum 6 12-06-2009 01:57 PM
how much draw with the key off? jeeptorino68 XJ Cherokee Technical Forum 11 09-18-2009 11:12 PM
Alright, so I did a parasitic draw test, and now my power locks won't lock... XJMuscle98 XJ Cherokee Technical Forum 8 01-19-2009 09:12 AM
Current draw from power seats @ 12v... ki1022 XJ Cherokee Technical Forum 1 04-13-2006 10:39 AM
Power Windows and Power Locks problem... Josh_is1 XJ Cherokee Technical Forum 4 06-11-2005 04:45 PM
