Power door looks wont work... for either door. - JeepForum.com
post #1 of 8 Old 05-08-2013, 10:11 AM Thread Starter
cmarshall21
1997 XJ Cherokee
Ok so the other day i was having issues with my passenger front window, took off the door panel took out what held the window and door lock switch and took it apart to clean and black sutt for good continuity. Put it back on window worked....
Now my Door lock switch doesn't work (doesnt unlock any door). U hear it click over so it would normally, but you don't hear the bars that lock the door move. and now my drivers side electrical door lock doesn't work (for any of the doors).
Im guessing the master side doesnt work because the passenger side isnt working, so the circuit isnt complete.
So is there a way to fix this?
cmarshall21 is offline
post #2 of 8 Old 05-08-2013, 12:34 PM
bamasteeler
did you check the fuse? believe it is number 15 on fuse panel.. should be a 25 am fuse.
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #3 of 8 Old 05-08-2013, 01:28 PM Thread Starter
cmarshall21
1997 XJ Cherokee
the fuse is good
post #4 of 8 Old 05-08-2013, 01:36 PM
bamasteeler
Originally Posted by cmarshall21
the fuse is good
Do you have power to the switches?
1980 Jeep CJ7
1999 XJ CLASSIC
post #5 of 8 Old 05-08-2013, 01:58 PM Thread Starter
cmarshall21
1997 XJ Cherokee
the drivers side should, I never took off the module
post #6 of 8 Old 05-08-2013, 02:07 PM
bamasteeler
The way the schematic looks, power is fed to passengers module then to individual locks, drivers switch just looked like it grounded the circuit when actuated.
1980 Jeep CJ7
1999 XJ CLASSIC
post #7 of 8 Old 05-09-2013, 03:03 PM Thread Starter
cmarshall21
1997 XJ Cherokee
where did u look at the schematic? link possibly? But yeah after looking into stuff i think i need to replace the passenger module so i ordered a new one
post #8 of 8 Old 05-10-2013, 03:42 AM
bamasteeler
I got maintenance manual on cd, mines a 99 but essentially 97-01 are all the same except when they switched to coil packs on 01's. and maybe 00's?? Not sure but everything else pretty much same......jeep (Chrysler) not known for reinventing the wheel lol
1980 Jeep CJ7
1999 XJ CLASSIC
door lock , door locks , electrical issue , power lock
