-   -   Power door looks wont work... for either door. (http://www.jeepforum.com/forum/f11/power-door-looks-wont-work-either-door-1520473/)
cmarshall21 05-08-2013 11:11 AM
Ok so the other day i was having issues with my passenger front window, took off the door panel took out what held the window and door lock switch and took it apart to clean and black sutt for good continuity. Put it back on window worked....
Now my Door lock switch doesn't work (doesnt unlock any door). U hear it click over so it would normally, but you don't hear the bars that lock the door move. and now my drivers side electrical door lock doesn't work (for any of the doors).
Im guessing the master side doesnt work because the passenger side isnt working, so the circuit isnt complete.
So is there a way to fix this?
bamasteeler 05-08-2013 01:34 PM
did you check the fuse? believe it is number 15 on fuse panel.. should be a 25 am fuse.
cmarshall21 05-08-2013 02:28 PM
the fuse is good
bamasteeler 05-08-2013 02:36 PM
Originally Posted by cmarshall21
the fuse is good
Do you have power to the switches?
cmarshall21 05-08-2013 02:58 PM
the drivers side should, I never took off the module
bamasteeler 05-08-2013 03:07 PM
The way the schematic looks, power is fed to passengers module then to individual locks, drivers switch just looked like it grounded the circuit when actuated.
cmarshall21 05-09-2013 04:03 PM
where did u look at the schematic? link possibly? But yeah after looking into stuff i think i need to replace the passenger module so i ordered a new one
bamasteeler 05-10-2013 04:42 AM
I got maintenance manual on cd, mines a 99 but essentially 97-01 are all the same except when they switched to coil packs on 01's. and maybe 00's?? Not sure but everything else pretty much same......jeep (Chrysler) not known for reinventing the wheel lol
The time now is 09:08 PM.
