Power Door locks - JeepForum.com
post #1 of 9 Old 05-11-2006, 03:22 PM Thread Starter
cherokee99spt
Power Door locks
I just bought a 99 jeep cherokee sport and the power door locks dont seem to be working. When i click the in car button over nothing happens. Should i check the fuses or is this a result of something else malfunctioning? thanks
cherokee99spt is offline
post #2 of 9 Old 05-11-2006, 04:46 PM
RWB214
RWB214's Avatar
The fuses are the first thing you should check before troubleshooting. If they are ok, let me know and I can help you troubleshoot further.
RWB214 is offline
post #3 of 9 Old 05-11-2006, 05:04 PM
PoPilot
Check the battery in the remote!
PoPilot is offline
post #4 of 9 Old 05-11-2006, 05:07 PM
Ghostjacker
i don't think he's referring to remote entry. of course i'm usually wrong about everything
edit: if you have remote entry.. does it work that way? i'm guessing you don't since you didn't mention it.
could also be broken wiring between the door and the jeep in the hinge area.
(try all the doors to see if you can use the locks from any of them. if some work, then it's probably a broken wire)
JEEP
Ghostjacker is offline
post #5 of 9 Old 05-11-2006, 05:08 PM
PoPilot
Man Im a dufus! He did say "in car button"!
PoPilot is offline
post #6 of 9 Old 05-11-2006, 05:16 PM
TheNerd
TheNerd's Avatar
My power locks on the '01 have been on the fritz also. It is pretty common for door speakers to die on the newer XJ's due to busted wires near the hinge. I assume the same thing is happening there. Do you power locks lock when you use the passenger side button? Do they work when you use the remote? Do you hear a click?
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #7 of 9 Old 05-11-2006, 05:21 PM
Ghostjacker
yeah i had to replace a speaker wire in my passenger side door hinge (so i'd say maybe it is also likely with the door locks.. although i don't think it's quite as common with the lock wires)
JEEP
post #8 of 9 Old 05-11-2006, 06:11 PM Thread Starter
cherokee99spt
Thanks for all the help guys but i did find the fuse blown and replaced it and the door locks now work. And for calrification it was both the inside buttons and the remote that were not working but the second i plugged in the un-blown fuse the locks made that noise that was music to my ears. Thanks again!
post #9 of 9 Old 05-11-2006, 06:59 PM
redyouch
if the key is in the ignition and the door is open, it wont lock.
90 Cherokee Laredo destroyed
93 Cherokee Sport destroyed
88 Cherokee LTD junked
98 Cherokee Classic totaled
95 Cherokee Sport flipped
87 Wrangler sold for a profit... :)
redyouch is offline
Power Door Locks zman4 XJ Cherokee Technical Forum 0 12-14-2008 07:48 PM
Power Door locks Untouchable XJ Cherokee Technical Forum 2 05-30-2007 11:24 AM
Power Door Locks smachan XJ Cherokee Technical Forum 3 02-16-2007 09:19 AM
Power Door Locks EclipseMGP XJ Cherokee Technical Forum 2 07-20-2005 08:47 AM
power door locks? tbone69 XJ Cherokee Technical Forum 2 01-19-2004 01:23 PM
