power distribution center for 1998 xj limited - JeepForum.com
post #1 of 7 Old 09-05-2009, 01:28 PM Thread Starter
racerdude_9
i desperatly need a diagram that tells me what fuse is what. ive looked around for 2 hours and i cant find a diagram that matches my jeep. well i found one diagram but i couldnt understand how to read it, it was very poor. i keep blowing this 15amp fuse while driving and it kills all my guages. and wont fire just turns over. then when i replace the fuse it starts and it barely runs and it pours way to much fuel. that fuse isnt the whole problem. but if i can figure out what that fuse is for it will give me some ideas of what the problem is. the jeep runs like its out of time, and i have injectors stuck open.
-1998 cherokee xj limited.. current daily driver.
-1991 dodge w250 cummins.. old daily driver and regular tire burner
racerdude_9 is offline
post #2 of 7 Old 09-05-2009, 02:31 PM
sprintagogo
Don't you have a label on the underside of the PDC lid?
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline
post #3 of 7 Old 09-05-2009, 02:54 PM Thread Starter
racerdude_9
yah but it just tells me the amps of the fuse. not what the fuse is for.
post #4 of 7 Old 09-05-2009, 10:30 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
CJ7-Tim is offline
post #5 of 7 Old 09-05-2009, 10:34 PM
toledotimber
toledotimber is offline
post #6 of 7 Old 12-19-2010, 05:20 PM
jhd405
light blue 15 amp fuse
Hi I have a 1998 jeep cherokee 4.0. I am having the same exact problem. The same light blue 15 amp fuse in the power distribution center keeps blowing. My car shut off in the middle of a highway, replaced fuse. Then i got anotehr 45 minutes and it did the same thing. Replaced the fuse and it instantly blew it again. Its in the row with the fuses: 15 15 25 15. It is the second 15 from the left. I'm thinking theres a short somewhere or someone told me my fuel pump might be going but not too sure. Any help would be greatly appreciated. Thanks
jhd405 is offline
post #7 of 7 Old 12-19-2010, 05:46 PM
CJ7-Tim
CJ7-Tim's Avatar
Fuse 22 is the fuel pump relay fuse. Buy a new relay and try that. If the problem continues, check the the fuel pump wires at the gas tank. Cherokee fuel pumps seldom fail.
CJ7-Tim is offline
wire diagram of tha distribution center under tha hood omohundro XJ Cherokee Technical Forum 3 11-08-2009 06:07 PM
HELP! Power Distribution Fuses 13bullets XJ Cherokee Technical Forum 0 02-28-2009 02:25 PM
Power Distribution Center/ Missing Fuses insurrection151 XJ Cherokee Technical Forum 0 06-11-2007 06:23 PM
Power distribution? denn34 XJ Cherokee Technical Forum 5 03-16-2007 11:45 PM
Has anyone relocated their Power Distribution Center (fuse block)? EricsXJ XJ Cherokee Technical Forum 2 02-11-2007 10:47 PM
