Power...Comfort...BLOWER! Or, how I quit changing shift points with my knee. - JeepForum.com
post #1 of 4 Old 03-06-2011, 02:31 PM Thread Starter
keepishop
1989 XJ Cherokee
This is a hack to turn the retarded comfort/power switch into a useful fan control switch. Note that this only works for RENIX cherokees.
First, under the hood find the sensor going into the driver side of the radiator and cut the wires. Splice the connector end onto a new pair of wires going through the firewall (needs to be long enough to reach the switch location). I used butt splices here for better heat and vibration resistance.
If the sensor was unplugged, then knowing this location will be helpful. The fan control plug is between the ballast resistor and the air box.
Ok, now tear open your dash. Remove the cigar lighter, the clock, and the panel with the transmission switch on it.
Cut the three wires going to the black plug on the back of the trans switch. Twist the harness side tan and black with yellow stripe wires together to lock the trans in power mode. If you like comfort mode better, just tape them off. Tape off the solid black
ground wire for safety's sake, since its right by the cigar lighter. Twist and tape the wire from the sensor plug through the firewall to the tan and blk/ylw wires on the switch side. This will cause the power setting to short the wires, and turn on the fan.
Bolt it all back together, and enjoy the manual fan control, while maintaining a clean dash look.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #2 of 4 Old 03-06-2011, 06:27 PM
xGArfx
looks like a cool mod, is the power comfort switch just a relay? i wired my aux e-fan with a relay that just runs power to the positive on the fan, works great. I'd also suggest getting a 97+ aux e-fan as it has 10 blades and pulls more cfm than the older style. Currently I'm looking into doing a taurus fan swap but its a bit more complicated then just putting a switch in lol trying to put a fan controller also so we shall see.. Good write up for the renix boys!
xGArfx is offline
post #3 of 4 Old 03-06-2011, 07:32 PM Thread Starter
keepishop
1989 XJ Cherokee
The power switch is just a normal lighted switch. I'm just using it to fool the jeep into thinking the rad is hot. I actually do have the 97 fan and it does blow way more air.
Bleed or Quit.
post #4 of 4 Old 03-07-2011, 01:21 PM Thread Starter
keepishop
1989 XJ Cherokee
Bumping for karma...
Bleed or Quit.
Power/Comfort in 3rd? RamboPants XJ Cherokee Technical Forum 3 08-10-2009 05:59 PM
Blower Motor Quit Again? RobV XJ Cherokee Technical Forum 5 12-12-2007 09:13 AM
Help! Aux Fan and ac/heat blower quit! russkrs XJ Cherokee Technical Forum 8 05-10-2005 10:10 AM
power/comfort heathen3226 XJ Cherokee Technical Forum 6 12-28-2003 03:16 PM
power comfort xjfreak XJ Cherokee Technical Forum 1 01-22-2003 10:24 PM
