Popping sound in the front end - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Popping sound in the front end
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 06-18-2009, 09:13 PM   #1
xjse
So I have a problem that has caused me a lot of grief lately. My cherokee has been making this loud popping sound that I can kinda feel through the floor every time I turn, or the weight of the vehicle shifts, or when one wheel lifts quiker than the other.
I was told by one shop that it was my ball joints, then another shop told me they were fine. I replaced my sway bar bushings, along with the sway bar links and bushings, now the popping sound seems to be even louder.
WHAT THE HELL IS WRONG WITH MY JEEP?????
ANYthing helps. Thank you for your time.
xjse is offline   Reply With Quote
Unread 06-18-2009, 09:17 PM   #2
beneharris
1995 XJ Cherokee
check for parts rubbing together. maybe two things are touching and popping off when the suspension flexes or changes a little
1995 Jeep Cherokee- 5" lift, Locked Up Fab Long arms, 31" Km2's. AA SYE kit, with Xj front driveshaft. Dual 12" Pioneer Subs
1967 Restored Volkswagon Bug- DD
Christian Jeep Member #133
beneharris is offline   Reply With Quote
Unread 06-18-2009, 09:18 PM   #3
ComancheKid45
1988 MJ Comanche
Sounds like your Trackbar joint.....they have a tendincy to egg out the bolt hole and gain some play over time, mine pops occasionally but not much as your describing. it would be something to check out though
ComancheKid45 is offline   Reply With Quote
