Popping Noise In 4 wheel drive only - JeepForum.com
post #1 of 13 Old 01-06-2011, 09:57 PM Thread Starter
critmuncy99
Well got a strange noise comeing from the frontend this only happens when Im in
4 wheel drive and turning the wheel maxed left or maxed right while the jeep is moveing..Does not do it sitting steel ..It is a popping noise comeing from the driver
side. 2 wheel drive everything is smooth and fine lol..So what could this be .Give me
my list of options ..The jeep does not make no noise going straight in 4 wheel.Thanks alot .Feel free to chip in your opinions ..
critmuncy99 is offline
post #2 of 13 Old 01-06-2011, 10:54 PM
Topgun514
1988 XJ Cherokee
Check front u joints.
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
post #3 of 13 Old 01-06-2011, 10:56 PM
FairlanePhil
FairlanePhil's Avatar
I second front U joints.
Look thru the FAQs for a How-to. I'd also do the front hubs with Timken bearings while its apart as a maintenance measure.
When you slide the front axles in do it CAREFULLY so as not to mess up the axle seals that are inside near the centersection
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
post #4 of 13 Old 01-06-2011, 11:03 PM
LankyXJ
Mumbling Jeeper
LankyXJ's Avatar
Do you feel it in the steering wheel when the popping sound occurs?
Barrett
Originally Posted by hubs97xj View Post
So, did you punch yourself in the face with a wrench hard enough to nearly knock yourself out? That's the best.
LankyXJ is offline
post #5 of 13 Old 01-07-2011, 01:05 AM Thread Starter
critmuncy99
Yeah just a lil bit. If feels like Im on dry pavement in 4 wheel drive when im turning the wheel maxed..But im not im on gravel/mud..
post #6 of 13 Old 01-07-2011, 01:26 AM
Willy36
1990 XJ Cherokee
full lock could still be too much for how much traction you have....i never like cranking the wheel all the way in 4wd
Willy36 is offline
post #7 of 13 Old 01-07-2011, 11:23 AM Thread Starter
critmuncy99
Plus it dont help with 235/75/15 and all bone stock with no lift lol
post #8 of 13 Old 01-07-2011, 01:04 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
You might check the center ball in your front DS universal. Mine got dry and rusted up once--the first time I pulled the ugly stick in a snow storm it sounded like someone had thrown a handful of gravel into the front diff. After a rebuild I now make SURE it gets greased (need to use a right-angle needle adapter on the grease gun to get to the fitting). Just a thought. Mine never made a peep in 2WD.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #9 of 13 Old 01-07-2011, 01:50 PM Thread Starter
critmuncy99
Well I checked the axle u-joints and they r in good shape. The sound is not constantly, just occasionally when I turn the
wheel maxed in 4-wheel drive while slowly rolling. Do you all think It could be the 235/75/15 hitting something ,I hope anyways lol.I havent off-roaded my jeep much sinced I have owned it.The jeep is bone stock.
post #10 of 13 Old 01-07-2011, 03:01 PM
crazyjeep
1975 CJ5
could bee the tire catching the control arm. my 96 would do it with 235s and stock suspension. youll see the rub mark.
crazyjeep is offline
post #11 of 13 Old 01-07-2011, 03:29 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Mine rubbed the lower control arms also with 235/75 bfg all terrains. If the u-joints check out and the tires aren't rubbing it may just be the u-joints binding at full lock in 4wd.
xjfever is offline
post #12 of 13 Old 01-07-2011, 06:19 PM
98_XJ
What causes the binding?
1998 Jeep XJ Limited 4x4
- Rough Country Series II 3" Lift
- 31-10.50-15 Duratracs on Black Rocks
- JCR Offroad Stage 3 Front Bumper
2010 Chevy Equinox
98_XJ is offline
post #13 of 13 Old 01-07-2011, 06:44 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Too much of an angle for them to tolerate.
xjfever is offline
Whining noise 4 wheel drive sterling541 XJ Cherokee Technical Forum 1 11-08-2010 05:58 PM
Popping noise when steering wheel turns cherokeekid58 XJ Cherokee Technical Forum 6 07-22-2010 05:19 PM
4 wheel drive cherokee broken popping out AntSki48 XJ Cherokee Technical Forum 5 01-02-2010 03:07 PM
Bad Popping Noise CherokeeDude XJ Cherokee Technical Forum 1 10-23-2006 04:03 PM
4 wheel drive makes weird noise... among other problems weldmaster4000 XJ Cherokee Technical Forum 10 01-30-2006 08:48 AM
