Pls identify these parts 1996 XJ - JeepForum.com
post #1 of 7 Old 11-04-2013, 08:52 PM Thread Starter
BeachDriver
could you kindly tell me the name of the two leaking parts in the pic from front suspension on my 1996 XJ and the best brand and place to order them from?
Thank you.
( Edit: wheel is on front drivers side )
BeachDriver is offline
post #2 of 7 Old 11-04-2013, 10:06 PM
krabby124
Looks like a tie rod and an axle seal
XJ Build Thread
YJ Build Thread http://www.jeepforum.com/forum/f22/95-high-school-yj-build-1411192/
krabby124 is offline
post #3 of 7 Old 11-04-2013, 11:25 PM Thread Starter
BeachDriver
Thank you !
( couple more pics I took )
post #4 of 7 Old 11-05-2013, 04:07 AM
Holder350
1995 XJ Cherokee
The axle seal should probably be addressed. The tie rod is just from over greasing or a ruptured boot. Neither is a huge issue to worry about until the joint fails.
Sent from my phone where correct grammar is difficult.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #5 of 7 Old 11-05-2013, 08:34 AM Thread Starter
BeachDriver
Thank you..Appreciate it !
post #6 of 7 Old 11-05-2013, 03:10 PM
rugsucka
To fix the axle seal involves pulling the entire carrier out - not exactly hard, but parts need to be put back at proper torque and in the same place they came from (bearing caps etc.)
That axle-shaft Ujoint looks old and crusty. If you're pulling the diff apart to fix a leaky seal, you should take the time to also toss in a new set of ujoints on both sides.
rugsucka is offline
post #7 of 7 Old 11-06-2013, 11:03 AM Thread Starter
BeachDriver
Thanks for the sound advice !
