Please Help!! P0138, P0141 - JeepForum.com
post #1 of 6 Old 12-22-2013, 09:56 PM Thread Starter
Willscharowkee
Hey everybody, I'm new here earlier this year my car was stolen and I acquired a 98 XJ for $500 with 170k on it. So far I have put about $1000 in parts onto it, (junkyard rear for bad pinion bearings VERY noisy, fuel pump-extended crank and bad FLS, cat converter-blown apart, spark plugs and wires, alternator, belt) I am a mechanic by trade so I save money on labor. I have repaired about 3 DTC's that were coming up except p0138 p0141 for the downstream O2 sensor. New sensor I put in is the larger bodied Bosch sensor, also checked the heater fuse underhood and it is good and has battery voltage with engine running and cleaned the ground on the block. I was hoping for a schematic for the downstream o2 sensor? Also wondering if anyone knows where underneath a chaff or break may occur besides the driveshaft, b/c thats fine. The reading remains at 450mv with the engine running for that sensor but sensor 1 does go down (and it is the original). I cannot pull my car in the shop I work at anymore (new owners) so I'll have to crawl underneath and start probing. Just hoping for some tips on locations if I do find it is in the harness. I have searched incessantly and keep finding the same answers. It is my only vehicle and I drive 400 miles a week to get to work. Any help is appreciated. thanks!
Willscharowkee is offline
post #2 of 6 Old 12-26-2013, 12:59 PM Thread Starter
Willscharowkee
I figured it out, both heater element wires open right above the transfer case, goodbye CEL
post #3 of 6 Old 12-26-2013, 01:13 PM
green97xjsport
1997 XJ Cherokee
What is a "FLS", and "DTC's", thought I was familiar with all the acronyms?!
,======o00o.
/__||_l__l,\___\,___
l_--\__\__l_---[]llllll[]
_(o))_____(o))--o-))
green97xjsport is offline
post #4 of 6 Old 12-28-2013, 09:22 AM Thread Starter
Willscharowkee
FLS= fuel level sensor DTC= diagnostic trouble code like p0300 engine misfire
post #5 of 6 Old 12-29-2013, 08:51 AM
green97xjsport
1997 XJ Cherokee
Yeah, it's been a while since I've use the 3 letter acronym for diagnostic trouble codes, since automotive school back in the 80's, just call them engine codes or check engine codes anymore, forgot about the fuels level sensors.
Did you get it figured out?
,======o00o.
post #6 of 6 Old 12-30-2013, 09:44 AM Thread Starter
Willscharowkee
It's ok I'm just a nerd cause I do this for work but yes I did fix it, I've been dealing with this for a while because I had so many other things to fix but I neglected to ever pull the body side of the o2 sensor connector from out of that little cover and when I did I found the 2 heated element wire were missing like they were yanked out and they were layin on the transfercase so I hard wired them to the 02 sensor and its working fine but I doubt if this 02 sensor fails they will warranty it with snipped wires but its been
Good so far! Shoulda checked that before I posted thought this might have been more complicated.
