please help! (heater problem) - JeepForum.com
post #1 of 10 Old 12-11-2009, 01:31 PM Thread Starter
beaver
First off, I drive a '99 cherokee with the 4.0. I just replaced the thermostat because it was sticking. No problem there, works fine. But now my heater wont get hot. Its way to damn cold to be driving around without a heater this time of year so I need to fix it asap. I took the day off work so I need to do it today.
I checked the water hoses from the pump to the heater area. The pump is puting out water just fine but it seems to be that it is getting blocked off somwhere at the heater. I think it might be the heater thermostat but I really dont know. Hopefully someone here can help.
Thanks in advance,
Josh.
beaver is offline
post #2 of 10 Old 12-11-2009, 01:42 PM
navymech
If there is water coming out of the heater core supply hose going into the heater core (when running=water pump working) and the engine is at it's correct operating temp, it sounds like the core is blocked by some crud.
Disconnect the hoses (carefully or you can break the core and cause much more pain!!) from the core and using a garden hose try to flush water each direction into the core. Eventually you should get it to start flowing and a bunch of garbage should come out. Keep flushing until you get good flow in both directions, reconnect hoses and top off coolant as necessary. This is what I have always done and unless the core is so full of concrete crud, it works most every time. You might want to consider flushing the engine as well or it can plug itself up again...
navymech is offline
post #3 of 10 Old 12-11-2009, 01:47 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
An air bubble in the system from the thermostat replacement would be my guess as the source of the problem. Check the radiator and see if the fluid is at the correct level. Leave the radiator cap off, turn the heat on, and start the engine. Keeping yourself and your clothing away from any moving engine parts, squeeze the upper radiator hose a few times every 30 seconds until the thermostat opens. Have some coolant on hand in case the coolant level drops. You will know when the thermostat opens, a small amount of coolant will surge up and overflow. When this happens, simply grab the radiator cap and install it.
CJ7-Tim is offline
post #4 of 10 Old 12-11-2009, 01:57 PM
Deezelweazel
Did you make sure the tiny hole in the thermostat is up to enable air to evacuate?
Check the heater hoses, both must be hot to the touch.
If not, see ^ Was the heater warm before you changed the thermostat? If not change the water pump too.
Deezelweazel is offline
post #5 of 10 Old 12-11-2009, 01:58 PM
96xjclassic
could also have a bad heater control valve.
Black 1996 Cherokee Classic-4.0L/AW4/NP231 Front-D30 Rear-C8.25
RC 4.5" lift w/full leafs akuza wheels and 31" Goodyear Duratracs
96xjclassic is offline
post #6 of 10 Old 12-11-2009, 02:03 PM
Deezelweazel
Its a 1999!
post #7 of 10 Old 12-11-2009, 02:11 PM
Kettles
Originally Posted by Deezelweazel View Post
Its a 1999!
yeah no heater control valve.
Flush the heater as mentioned earlier and you should be good. Its a common problem.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #8 of 10 Old 12-11-2009, 03:34 PM Thread Starter
beaver
thanks a lot fellas, will do!
beaver is offline
post #9 of 10 Old 12-11-2009, 05:12 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
What temp is the temp gauge running at? Should be a tick under 200. Gotta know what temp the engine is operating at as a baseline check.
If engine is at proper temperature, then the heater core is definitely suspect for blockage.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #10 of 10 Old 12-11-2009, 06:10 PM Thread Starter
beaver
it has always ran a tick over 200 and still does. I did some more tinkering and got the heater cleaned out but now I think the radiator is clogged. Im gonna take it to the shop tommorow and have them flush the radiator and motor and see if my problems stop. Its pretty nasty for sure.
beaver is offline
Heater Problem jeepnick XJ Cherokee Technical Forum 1 10-30-2009 01:25 AM
heater problem 99XJRider XJ Cherokee Technical Forum 1 12-12-2007 10:16 PM
ac/heater problem joe86 XJ Cherokee Technical Forum 4 11-10-2007 11:44 PM
heater fan problem skunkmere XJ Cherokee Technical Forum 4 10-20-2006 07:32 AM
Need Help with Heater Problem projectX XJ Cherokee Technical Forum 1 01-25-2004 08:11 PM
