Please help anyone, Rpms jump and fall! - JeepForum.com
post #1 of 3 Old 03-13-2012, 10:57 AM Thread Starter
x99XJsportx
My CE liight has been on and i finally checked it out, and i plugged it in. 2 codes came up, but this is the only one i remember; P0171. System Too Lean (Bank 1). but before you look that up, i know i have a crack in my manifold, and i understand it needs to get replaced. but whenever my engine heats up to normal temp, ill keep my foot steady and my rpms will just drop, then shoot up, and go up and down over and over while i keep my foot steady. but if i go over 3k it wont do it. after i let the rpms go back down it will want to die so i have to either put my food down and feel my jeep jump and jump and jump or go 3k plus on the rpms and go flying by. It does become very difficult to drive this way. especially when their are people in front of you.
If you were on the road next to me or in the passenger seat, it would look like i would stomp on the pedal and right away let go and jump on it again and let go, it is very frustrating so if anyone could help i would appreciate it! i will find the other code later and post it in an hour or two as I am working
x99XJsportx is offline
post #2 of 3 Old 03-13-2012, 11:03 AM
jeepnphreak
1989 XJ Cherokee
Give this a try and seed what happens to the code
A code P0171 may mean that one or more of the following has happened:
  • The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #3 of 3 Old 03-13-2012, 11:21 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Without knowing all the trouble codes, there is little you can do. Download and post all the exact code numbers.
What you can and should do first, is fix the cracked manifold.
P0171 Causes:
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust manifold leaks
- Incorrect fuel pressure
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
CJ7-Tim is offline
gas , idle , issue , jeep , rpm
Rpms Drop 200 Then Jump madfire XJ Cherokee Technical Forum 1 12-15-2009 02:53 AM
My door likes to fall off. BatmanGTO XJ Cherokee Technical Forum 0 10-20-2009 02:43 PM
wheeling in river fall, WI travail XJ/MJ Cherokee Non-Technical Forum 3 02-09-2009 07:11 AM
Help!!!! Is My Wheel Gonna Fall Off??? JeepShaun84 XJ Cherokee Technical Forum 10 11-07-2008 11:39 PM
Anyone ever had their motor fall out? MudColoredXJ XJ Cherokee Technical Forum 10 04-03-2005 08:24 AM
