Please help!! - Page 2 - JeepForum.com
post #16 of 17 Old 07-11-2010, 11:25 AM
justanotherjpr
Don't forget you'll need to put a good charge on the battery. A trickle charger, a good run on the freeway, or an auto parts store should be able to do it for you.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #17 of 17 Old 07-11-2010, 12:14 PM
keepishop
1989 XJ Cherokee
You need to disconnect the door buttons for the courtesy lights too to turn them off. Check any of the doorless threads for help with that.
Batteries do not like being run down to flat empty. If you do it too much it will not take a charge very well.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
door , removal , wire , cut , problem , starting
