Pinion seal constantly blowing after d30 locker install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Pinion seal constantly blowing after d30 locker install
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Eliminate Hood Flutter!!!Offset Tie Rod Kit From RuffStuff!
Unread 09-02-2013, 07:02 PM   #1
FleXJ96
I have done a few lunch boxes in Dana 30s before, so no big deal right? well wrong....
Only had the Jeep a few weeks before getting the locker, and noticed a small pinion leak , figured just old seal. When I pulled the cover almost no fluid came out. So I installed the spartan and bolted it all back up. I noticed it was puking oil out the pin bad, figured I just over filled. Had a buddy that is a tech at a shop replace seal for me just so I don;t mess up. Drove few miles home and seal is blown. Figured it was a fluke, replace with a Timken this time, maybe it was a cheap national seal before. first turn of Drive shaft it blew again. Now i'm stumped. Any one heard anything like this before? My buddy that helped with seal wants to pull pinion and carrier and redo it all . I'm just so frustrated right now.
Here is both of the new seals just a few miles on them . Any help or thoughts would greatly be appreciated. That and if anyone has a timken part number for the pinion seal to make sure I got the right one.
www.4LOWphoto.com Jeep and off road photography
www.Florida4x4.org A place for FL offroaders to gather.
My XJ Build Thread http://www.jeepforum.com/forum/f22/silver-bullet-xj-sport-24s-31s-1398256/
FleXJ96 is offline   Reply With Quote
Unread 09-02-2013, 07:26 PM   #2
mcthnif
Your vent is clogged.
mcthnif is offline   Reply With Quote
Unread 09-02-2013, 08:01 PM   #3
FleXJ96
That was my first thought as well and I will pull and check tomorrow. My concern is the guy that did the seals mentioned the yolk was hard to put back on and he had a good feeling it would destroy the seal again like it did without even thinking of the vent ...
Unread 09-02-2013, 08:51 PM   #4
mcthnif
If the vent isn't clogged, then I would think, the seal couldn't blow out, but could be ripped out by a damaged,"Yoke." If it turned out to not be the vent, then check the yoke for a deep groove, or a gouge bad enough to catch the seal.
Unread 09-03-2013, 11:18 AM   #5
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
A worn, damaged, or rusted yoke will tear up a seal fast.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 09-03-2013, 12:33 PM   #6
Timo_90xj
Timo_90xj's Avatar
Bad yoke or clogged vent tube. Vent tube would most likely not tear the lip of the seal like that though, only puke diff fluid out. So my bets are on a bad yoke.
Have you checked there is no play in the pinion bearings?
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote
Unread 09-03-2013, 08:18 PM   #7
FleXJ96
Come to find out it was the wrong yolk, and the guy that did the install just made it fit ... With a hammer . Got a real d30 yolk from a Buddy and issue solved. Not sure what this thing is out of. Same spline but way bigger OD.
Unread 09-03-2013, 09:15 PM   #8
mcthnif
Wow! That is one dangerous mechanic. Sorry You ended up with one like that.
Unread 09-04-2013, 01:43 AM   #9
Timo_90xj
Timo_90xj's Avatar
Good that you found the reason. Having a bigger yoke wouldn't actually have been an issue, had the mechanic also installed a correctly sized pinion seal to match the yoke OD.
Now, just remember a driveshaft attaches to a yoke, yolk is what you find inside eggs
Unread 09-09-2013, 08:17 PM   #10
FleXJ96
Hah thanks
