pinch seam on rear fenders - JeepForum.com
post #1 of 4 Old 05-12-2004, 09:20 AM Thread Starter
silverxj2001
silverxj2001's Avatar
Angry pinch seam on rear fenders
yeah, i was doing some fender trimming and remembered halfway through that i had broken the pinch seam. what should i do?
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
silverxj2001 is offline
post #2 of 4 Old 05-12-2004, 09:33 AM
mission-inc
mission-inc's Avatar
Ouch.
I'm sure you can weld them together... If you haven't done to much damage, you may be able to fold it under and just make relieve cuts in the part that hasn't been hacked up yet (so it'll bend easier). There are abunch of threads reguarding this that have just been posted, try searching. There are also thread on www.jeepin.com about doing this.
Good luck!
1995 Jeep Cherokee Country
AW4, NP231, 4.0L I6
7.5" lift, 35's, 8.8 out back, 4.56's, etc.
mission-inc is offline
post #3 of 4 Old 05-12-2004, 12:12 PM Thread Starter
silverxj2001
Originally Posted by mission-inc
Ouch.
Good luck!
ill probably get someone to weld it back shut. but could you post the link to that exact thread on jeepin.com? i wasnt able to find it.
6.5" RE
33x10.5" BFG A/T KO
RE adj. LCA/UCA's
intake / exhaust
procomp lighting
post #4 of 4 Old 05-12-2004, 12:19 PM
RockinXJ
RockinXJ's Avatar
If you don't want to get it welded, but want to keep water and dirt out, just get a can of GREAT STUFF expanding foam and fill in the gap. I cut through some of my seams on purpose and I just filled the gaps with that stuff and I've had no problems with debris getting inside.
If you light a fire for a man you'll keep him warm for a day, but if you light a man on fire, you'll keep him warm for the rest of his life!
I ♥ Transitive Pictograph Verbalizations
RockinXJ is offline
inner fender: cut & fold pinch seam? the303hooligan XJ Cherokee Technical Forum 7 04-01-2009 07:30 AM
No rear pinch welds on 01 xj? DeepJeep XJ Cherokee Technical Forum 11 02-09-2009 07:29 PM
Do TJ rear flares work on chopped rear XJ fenders? loudog3114 XJ Cherokee Technical Forum 4 10-21-2006 01:17 PM
cutting the pinch seam for rock rails? aussiewheeler XJ Cherokee Technical Forum 35 05-26-2006 06:45 AM
Rocker panel pinch seam HCA-Bronco XJ Cherokee Technical Forum 5 01-18-2006 03:13 PM
