Picture wanted! Renix knock sensor - JeepForum.com
post #1 of 13 Old 05-10-2009, 02:23 PM Thread Starter
keepishop
1989 XJ Cherokee
I think my knock sensor is broken, but the problem is that I have only found it once. Does anyone have a diagram of where it is, or a picture that shows it? Google has failed me, and I'm starting to feel really dumb about not being able to find it on my block again.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #2 of 13 Old 05-10-2009, 02:59 PM
Ed Rico
1997 XJ Cherokee
From RockAuto.com:
-Ed Rico
Ed Rico is offline
post #3 of 13 Old 05-10-2009, 06:58 PM Thread Starter
keepishop
1989 XJ Cherokee
Well, I found it again today and took pictures. I'll post them later when I'm on my laptop.
For those that care, the knock sensor is located on the driver side of the block just to the right of the motor mount. Honestly, why have I never seen that documented before?
Bleed or Quit.
post #4 of 13 Old 05-10-2009, 08:13 PM
Saudade
1988 XJ Cherokee
Saudade is offline
post #5 of 13 Old 05-11-2009, 09:59 AM Thread Starter
keepishop
1989 XJ Cherokee
Mine is a different style. I plugged the cable back onto the terminals, and since then it has been running a little funny, I'll have to check some schematics and see what I did wrong. Probably backwards.
Bleed or Quit.
post #6 of 13 Old 05-15-2010, 08:37 AM
tommyp77
Now i have a problem where i found this sensor but i cant find the cables or wire thats supposed to plug onto it. Where is the wires originating from? Anyone have pics of that, so i might be able to trace the problem back and see if my wire even exits?
THank you for all the help in advance!
tommyp77 is offline
post #7 of 13 Old 05-15-2010, 08:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
It probably won't affect how it runs anyway if you have a driveability problem. All it does is send a signal, that it generates only when it hears pinging, to the ECU so the ECU will retard the timing a bit.
cruiser54 is offline
post #8 of 13 Old 05-15-2010, 08:53 AM
4jeepers
Junkyard part. Unless they are physically damaged or the wires broken they rarely go bad! From your picture I would say that the molded plug on the sensor is broken off, the plug hanging below the sensor should be the connection to the sensor!
4jeepers is offline
post #9 of 13 Old 05-15-2010, 08:56 AM
Saudade
1988 XJ Cherokee
What year? The knock sensor was eliminated in '91 and are specific to Renix.
Saudade is offline
post #10 of 13 Old 05-15-2010, 09:20 AM
tommyp77
Well thats not my pic, i just used the pic from post above, i dont have a wire hanging there. My jeep is a 94 yj 4.0.
Thank you
The problem is my mil is on and the jeep sputters on acceleration, and its eating a bit too much.
Going to have my mil diagnosed today. It might not even be that. But like Saudade writes, i might not even have it?
tommyp77 is offline
post #11 of 13 Old 05-15-2010, 05:11 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You don't have it. What is your CEL indicating?
post #12 of 13 Old 05-15-2010, 05:22 PM
tommyp77
Well after getting the scan, it indicated 3 things, my alternator, something with the ac compressor(which i know i dont have) and the tps.
I had him clear it cause alternator i changed previous weekend, and i put a relay into the ac slot on fuse panel just so its there(doubt it makes a difference)
On second scan, only the tps came up.
Took $50 for new tps sensor and 5 min to change, and the light went out and jeep runs 10x better!!, No more sputtering on acceleration.
I guess i only have the knock sensor on the block cause its originally from a cherokee, i wasnt sure if the one i droped out months back had one or not.
Guess i had it pegged wrong.
Thank you all!
tommyp77 is offline
post #13 of 13 Old 05-16-2010, 01:38 PM
dover21
I just replaced mine the other day. In your pic yours is broke just like mine. The pics from Rockauto are correct for the new one. Once you disconnect the old one and install the new you'll see that the plugs match up perfectly.
There is a way out of everything, man. Just keep your pecker hard and your powder dry and the world will turn. King, Platoon
We hold these truths to be self-evident, that all men are created equal, that they are endowed by their Creator with certain unalienable Rights, that among these are Life, Liberty and the pursuit of Happiness.
dover21 is offline
4.0 renix motor. IACV sensor location. judd_123 XJ Cherokee Technical Forum 2 12-03-2009 09:01 PM
Renix-Crank Postion Sensor Location Hunterdad XJ Cherokee Technical Forum 13 11-21-2009 06:39 PM
renix with knock sensor un-plugged ? sourskittle XJ Cherokee Technical Forum 11 01-20-2008 03:06 PM
Renix - Sensor value help BIG1RED9 XJ Cherokee Technical Forum 7 11-24-2006 12:15 PM
Renix knock sensor krzcwby XJ Cherokee Technical Forum 2 04-09-2006 02:52 PM
