Quantcast Pics of XJ's w/ Full Size Axles Requested - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Pics of XJ's w/ Full Size Axles Requested
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 10-17-2006, 08:44 PM   #1
HEAPXJ
I recently acquired a rear Dana 60 and I was thinking about putting it in my beater XJ. I just want to see some other Jeeps doing the same thing so I can get an idea of what it's going to look like. Thanks guys.
HEAPXJ is offline   Reply With Quote
Old 10-17-2006, 09:35 PM   #2
wil badger
uhm so you are going to dump a full width axle in the rear but leave a stock axle up front?the 60 is a boat anchor unless you plan on running 35's or bigger.i also notice you live in CT ,what are their tire and flares laws like.how far can you stick out before not passing inspection or being harassed by the local P.D.
i believe you need to think about this more then you have.
now on to what you asked for
here is a full width axle build up of a 44/60
now with the correct offset and flares you can almost make it under
One Built XJ
wil badger is offline   Reply With Quote
Old 10-17-2006, 09:40 PM   #3
natedawg87317
that looks awsome
nate
2005 TJ unlimited. soft top 6spd. soon to have a 2 inch lift and 32'S
restored 72 chevy long bed\yellow green metalic
natedawg87317 is offline   Reply With Quote
Old 10-17-2006, 09:44 PM   #4
Meatroach
1992 XJ Cherokee
O M F G THAT'S AWESOME !
XJ
[COLOR="Red"]3.5" Warrior coils, Full leaf packs, Skyjacker Quick Disconnects, Rear swaybar delete, Pro Comp shocks, HD Steering stabilizer, BFG AT's, 1" drop shackles, Front tow hooks,Front skid, Warn T-case skid
bcjeepclub.ca
Meatroach is offline   Reply With Quote
Old 10-17-2006, 10:26 PM   #5
wil badger
i guess you guys missed this thread Death of an Xj
One Built XJ
Old 10-17-2006, 10:35 PM   #6
white98xj
does anyone know if The front axle out of an international scout is full width or is it about the same as the stock cherokee axle? I would like to have both front and rear D44's......
| 98 Jeep Cherokee | 4.0L Straight Six | AX-15 5-Speed | NP 231 | Dana 30 | Chrysler 8.25-29 Spline |
| Old Man Emu 3" Heavy Duty Spring Rate | Alpine CDA-9853 | Uniden 520XL CB | K40 Antenna (56" Whip) | RLF CB Mount | Flowmaster Super 44 | Duals |
| AR Ansen Sprint's on 31x10.5" BFG Rugged Trails-Summer |
| Stock Wheels on 30x9.5" AT's -Winter |
Dual Outlet Flowmaster Club- Super 44
Dark Descendant Dirty Tees
Originally Posted by dcmanally
gas + matches + house = solution.
white98xj is offline   Reply With Quote
Old 10-17-2006, 10:51 PM   #7
Meatroach
1992 XJ Cherokee
No will......I'm just trying to move on. and no matter how many times i look at your rig (may it rest in peace) i am in awe. Can't wait to see your next project........made any new progress?
XJ
bcjeepclub.ca
Old 10-17-2006, 11:38 PM   #8
HEAPXJ
No no, I mean that I just got a Dana 60 for the rear. I'm in the process of finding a full width 1 ton for the front. I posted this thread to see what other people are doing with 1 tons. Hey Wil, what was the back-spacing of those wheels on your old Jeep? Thank you for the build link.
Old 10-18-2006, 12:31 AM   #9
wil badger
well you still aren't thinking this fully through.the problem with dropping a 1 ton axle up front (which would be a 60) is a weight issue.if you are looking for a front 60 it would have to be out of a 78/79 Ford F350.this would make it a high pinion as well as the correct side drop.now if you plan on putting a dana 300 case or something else in to make it passenger side drop then it would have to be out of a chevy or dodge.
now we are back to the weight issue.with all that weight you will tear the Xj in half with out fully plating the uni-frame.it just can't take that kind of stress.even a full width 44 is asking to much of the front half of the vehicle.this is why i chose a 44 for my build .
this is what i found while tearing it down .this is from the added weight of the front axle and tires(look closely between the windshield post and hood)
Xj just aren't up to the task as far as i'm concerned with out major revamping of the frame system.
now as for the back spacing i was running 5" backspacing.with anything more then 4 and 3/4 you will have to have arms that bend in pretty good or you will have rubbing issues during full steer.
One Built XJ
Old 10-18-2006, 01:36 AM   #10
HEAPXJ
Thanks Wil for the advice. I'm not planning on doing it overnight. I plan on basicall making a buggy derived from an XJ. There's going to be tube everywhere, haha. It looks like you really drove that thing to death to get stress cacks like that. Thanks again for pics. I look forward to seeing the TJ in action. - Ben
Old 10-18-2006, 07:23 AM   #11
wil badger
well i'm sure you have heard it and read it a hundred times here..........go to NAXJA register and start searching there for things to do to make this happen .its the best place for information on XJ and how to beef them up ,truggy them out ,and make it happen.this forum is just a waste of time for such question .
One Built XJ
Old 10-18-2006, 08:09 AM   #12
Walton99
Here's a couple of mine, disregard the crappy steering in the front, it's since been upgraded with dedenbear knuckles, BTF high steer arms, and a hydro assist. The axles are a ford 9" and a hp44.
'01 XJ
Hp44, Ford 9", 37" MTR's, 5.13's
Originally Posted by Helicop
a true "pandora's box" of off-road machinery.
Gig'em Aggies
Walton99 is offline   Reply With Quote
Glock Forum
