Quantcast pics of homemade air intakes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > pics of homemade air intakes
Old 01-06-2009, 06:04 PM   #1
sdkcabral
im going to make a air intake for my 4 L. any pics thanks
sdkcabral is offline   Reply With Quote
Old 01-06-2009, 06:56 PM   #2
1996xj
If you want better flow you can simply drill a 2in hole(s) in the front of the airbox. Seems to change the tone of the exhaust a bit.
1996xj
3" Rough Country Lift, 3in shackles, 3 RC shocks, 31" BFG ATs, 2 KCs, Lighted Roofrack, Soft 8s, TC drop, Custom oil leak deflector.
If only i could get a set of tires to last me 10,000Miles
Originally Posted by toates89
i am just gunna drive around in 4lo on dry streets, and peel out
Originally Posted by 4.0H.O.XJ
I once got a ticket for jerking while driving it. The cop wouldnt let me use his pen to sign the ticket.
1996xj is offline   Reply With Quote
Old 01-06-2009, 07:02 PM   #3
justanotherjpr
I did the MAD XJ stock modified airbox.
The rectangle flanges are off of an old full size cherokee at the junkyard. The rectangle to 3" round adapters are from a 4cyl AMC XJ. The round tube is from the parts store, 8.99.
I patched up the old hole in the front of the airbox with some scrap sheet metal, RTV, and bolts. Cut a hole in the firewall with a dremel and sawzall. Cut a hole in the airbox and screwed/RTV'd the flange on. You can really hear it whistle on cold mornings. As long as the water is under my wipers, I'm good. A nice bonus is my Jeep no longer sucks hot engine air into the airbox.
justanotherjpr is offline   Reply With Quote
Old 01-06-2009, 07:07 PM   #4
midfat
Snorkel?
Vents?
Scoop?
Watcha looking for?
midfat is offline   Reply With Quote
Old 01-06-2009, 07:17 PM   #5
XJKyle1389
can this be done with just round peices to go into the firewall and airbox rather than rectangular (cuz i have some of them sitting around)? Or is the rectangular one better fit for the air boxes?
XJKyle1389 is offline   Reply With Quote
Old 01-07-2009, 11:03 AM   #6
justanotherjpr
The rectangle fit my box well. If you had a flange that was a circle instead, as long as it fit on the airbox tight, I'm sure it would work.
Old 01-07-2009, 05:11 PM   #7
LilXJ
1994 XJ Cherokee
Hey, about the "snorkle" that vents out of the wiper box (where the wiper motor is) I didi the same Mod and i loved it in the summer! but there are 2 things that i want to throw out there. 1. make sure you cut a couple more holes to drain the wiper box! i just used a half inch bit and put like 3 in. and 2: in the winter ( i live in wisconsin) the wiper box vents get covered in snow and ice. on mine the wiper box actually filled with ice! i had to disconnect it inside the engine compartment because it was starved for air and when i started it it would suck and loose snow into the intake!
Just a little heads up. but as soon as the snow is gone i am hooking it back up though!
LilXJ is offline   Reply With Quote
Glock Forum
