PB Blaster for Engine Ground??? - JeepForum.com
post #1 of 6 Old 07-14-2012, 06:23 PM Thread Starter
aldersonfilm
Hey guys, so my 1990 XJ is running a little rough lately, so I'm trying to clean up the ground. Found the bolt on the block where the ground wires are. It's next to impossible to get past all the wires and hoses, but once I got in there, I realized that every time I tried to turn the nut, the wires would come with it. It's like they are seized onto the nut or something. I can't loosen the bolt because the wires start twisting with it.
So my question is, how do I get the nut unstuck from the wires?? PB Blaster? The nut is loose from the block, just not the wires. It's also covered in grime.
Help!
aldersonfilm is offline
post #2 of 6 Old 07-14-2012, 07:25 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Hold the stud with a wrench and turn the nut. It's an odd E-wrench or a small socket may hold it. The fact that the stud moves means it's really important to fix it.
Renix Ground Refreshing
The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, and wasted money replacing unnecessary components.
The components grounding at the dipstick tube stud are:
Distributor Sync Sensor, TCU main ground, TCU “Shift Point Logic”, Ignition control Module, Injectors, ECU main ground which other engine sensors ground through, Oxygen sensor, Knock Sensor, Cruise Control, and Transmission Sync signal. All extremely important stuff.
The factory was aware of the issues with this ground point and addressed it by suggesting the following:
Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Must be clean, shiny and free of any oil, grease, or paint.
Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Reinstall all the wires to the stud and tighten the nut down securely.
While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, and reattach securely.
Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for it’s intended use and subject to corrosion and poor connections at each end.
First off, remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Reattach securely.
Remove the other end of the cable from the rear of the head using a 3’4” socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely.
A suggestion regarding the braided cable:
I prefer to add a #4 Gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18” long with a 3/8” lug on each end works great and you can get one at any parts store already made up. Napa has them as part number 781116.
A further improvement to the grounding system can be made using a #4 cable, about 10” long with 3/8” terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. Napa part number 781115.
If you want to upgrade your grounds and battery cables in general, contact Jon at www.kelleyswip.com. He makes an incredible cable upgrade for a very reasonable price.
Revised 11-28-2011
cruiser54 is offline
post #3 of 6 Old 07-14-2012, 07:30 PM Thread Starter
aldersonfilm
The stud isn't loose. The stud it dine. The problem is that the nut that's on the stud appears to be soldered or welded to the wire for the battery. So when I turn the nut, the whole wire turns with it. Is the wire supposed to be soldered onto the nut???
post #4 of 6 Old 07-14-2012, 07:32 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
There was never any solder. PB Blaster may be what you need to use then.
post #5 of 6 Old 07-14-2012, 07:44 PM Thread Starter
aldersonfilm
In the Renix ground fix instructions though, it has says that the ground for the battery is forward of the dipstick. Mine isn't... Mine is also attached to the same ground as all the others, right behind the dipstick tube. Must have been something the previous owner did?
post #6 of 6 Old 07-14-2012, 07:48 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Could be. Nothing wrong with having them all together though.
connection , electrical , ground , nut , stuck
can I use WF40/PB Blaster on my engine parts? Back_In_Black XJ Cherokee Technical Forum 19 12-06-2009 11:46 AM
engine ground? skip11and1 XJ Cherokee Technical Forum 15 09-30-2009 09:41 AM
Engine ground? itasor XJ Cherokee Technical Forum 1 11-07-2007 03:24 PM
Engine to Chassis ground Dalamatition XJ Cherokee Technical Forum 11 09-03-2006 10:21 PM
Engine Ground Mr_The_Plague XJ Cherokee Technical Forum 5 07-14-2003 12:58 AM
