Passenger window won't go up! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Passenger window won't go up!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 06-09-2005, 12:02 PM   #1
kanadianXJ
Yeeeup, my front right passenger window won't go up. I've tried both controls, driverside and passenger side and nothing. Played around with window lock to see if that was the problem, and it doesn't seem to be. Any ideas? When the A/C is on, and I push the button, fan seems to go down a bit, so it would seem it is still getting power...
Thanks.
kanadianXJ is offline   Reply With Quote Quick reply to this message
Unread 06-09-2005, 12:22 PM   #2
sweenepj
A little more info would help, like is it a 2 door or 4 door? If it's a 4 door, are all 3 passenger windows showing the same problem? And what year is the jeep? A lot of people have had problems with the lockout switch on the newer cherokees, myself included... From what I've gathered, you can replace the switch assembly for $160 or something rediculous like that, or bypass the switch so the other windows are always unlocked.
Also, it could be the window regulator, but that would be more evident (like you still hear motor noise but the window won't go up). The stock regulator is a piece of crap on the newer cherokees. My driver and front passenger regulators both broke, and you can find some more info about that problem on the forums too.
If you need more info about either of those repairs on a newer cherokee let me know because I've done them :-)
sweenepj is offline   Reply With Quote Quick reply to this message
Unread 06-10-2005, 03:17 PM   #3
Roodki
I'd say it's probably the window regulator. To make mine temporarily stay up I pushed it up and clamped the post it slides on with a vice grips.
2004 Jeep Wrangler Unlimited
TSE - A Jeep Club
Roodki is offline   Reply With Quote Quick reply to this message
Unread 06-10-2005, 05:09 PM   #4
XJ-NoDough
My driver door window has this problem if I run it down too far. Open your door and with your finger pushing the button in the up direction, slam the door. Or with your finger on the button, punch the door panel right where the motor is on the inside.
[SIZE=2][B][COLOR=Blue][B]My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded[/B][/COLOR]
[COLOR=Red][B]4L Selec-trac[/B][/COLOR]
[COLOR=White][B]Automatic[/B][/COLOR]
[COLOR=Red][B]3"-4.5"ish Homebrew lift[/B][/COLOR]
[COLOR=White][B]16x8 MB Motoring Rockers[/B][/COLOR]
[COLOR=Red][B]265/75R16(31[SIZE="1"]ish[/SIZE]"X10.4") Goodyear Wrangler M/TRs[/B][/COLOR]
[COLOR=White][B]Trimmed w/ Bushwackers[/B][/COLOR]
[COLOR=Red][B]Stock 3:55 gears[/B][/COLOR][/B][/SIZE]
[B][COLOR=White]sans big audio[/COLOR][/B]
[B][COLOR=Red]Homebrew intake w/cone filter[/COLOR][/B]
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline   Reply With Quote Quick reply to this message
Unread 06-10-2005, 09:25 PM   #5
nvrdone
my '88 started the same thing a few months ago. Turns out one wire into the motor was loose. Pull the door panel off and have a look. Good luck.
nvrdone is offline   Reply With Quote Quick reply to this message
Unread 06-11-2005, 12:35 AM   #6
ATX XJ
i had both window regs go bad on my '00 and the glass just dropped into the door and wudnt move. cost about 600 to fix, but fortunately i had a warranty so it cost me 50 flat.
Cherokee 4.0 4x4 231/AW4 30/8.25 BLACK
TEXAS LONGHORNS
ATX XJ is offline   Reply With Quote Quick reply to this message
Unread 08-08-2009, 03:05 PM   #7
rspi
Simular problem on my 2004 Jeep Grand Cherokee Larendo.
My window actually went down and stayed down. The story goes... We pulled into a parking lot, closed the passenger door and watched the window go down all by itself. Drove home with the window down in 100 degree heat and decided to fix it the next day.
The problem was that the upper window track cable pulled through the plastic track guide. This is what I did to fix it, photo instructions: http://www.atthetipwebs.com/technolo...2004jeepgc.htm
Hope this helps.
rspi is offline   Reply With Quote Quick reply to this message
Unread 07-31-2015, 08:05 PM   #8
SylviJ
My 2004 4 door Grand Cherokee's left passenger window would not go down when operating from the driver's panel, so I tried the door button of the faulty window and it did. However, it won't go up. I tried to see if it was just stuck, so pressed both UP and DOWN settings. No go. It won't go down any further, but it won't go up either.
Someone tried pressing the door button while trying to PULL UP to at least get it up temporarily, but it still doesn't work. Now, I don't hear the click OR the movement sound.
Whatta' ya think? Thx!
SylviJ is offline   Reply With Quote Quick reply to this message
Unread 07-31-2015, 08:09 PM   #9
SylviJ
My 2004 4 door Grand Cherokee's left passenger window would not go down when operatingfrom the driver's panel, so I tried the door button of the faulty window and it did. However, it won't go up. I tried to see if it was just stuck, so pressed both UP and DOWN settings. No go. It won't go down any further, but it won't go up either.
Unread 12-05-2015, 03:53 PM   #10
IBWild
Any luck?
I'm curious if anyone has found the issue to this. I just picked up a 98 Cherokee Sport (4 door) and it's right front window won't roll up. Rolls down fine, rolls up fine when putting voltage direct to the motor. I've opened up both the master and right door switches, cleaned the switches with DeOxIT, re-soldered all the contacts, pulled the door boots looking for any broken wires. Still no joy... All the other windows work fine, so I'm not thinking that it's a lock out switch issue.
IBWild is offline   Reply With Quote Quick reply to this message
