Quantcast passenger rear brake light and reverse light not working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > passenger rear brake light and reverse light not working
Old 10-18-2009, 06:01 PM   #1
1limited
1987 XJ Cherokee
I'm trying to figure out why the reverse light and brake light are not working.I replaced all the bulbs but still nothing.Anybody got any ideas?BTW,thanks to those who posted replies to my door issue.Got it taken care of.
1limited is offline   Reply With Quote
Old 10-18-2009, 06:05 PM   #2
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
Is the problem on both sides, you have no reverse lights or brakelights? If so it sounds like a ground problem. If you have a multi-meter you can test for power at the sockets to see if there is a problem there. The ground is on the inside behind the panel where the spare goes.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 10-18-2009, 06:14 PM   #3
ehall
1991 XJ Cherokee
The external lights are constant ground with switched power, so if those lamps are not working on just the one side then the light-specific power wires in that harness are damaged. The connectors are probably corroded, it happens fairly often. Easiest fix is to grab a replacement at the junkyard or dealer, whichever you prefer.
ehall is offline   Reply With Quote
Old 10-18-2009, 06:16 PM   #4
1limited
1987 XJ Cherokee
Thanks for the reply xjfever.Yes,those are my symptoms.I'm going out now to check the ground.
Old 10-18-2009, 06:19 PM   #5
1limited
1987 XJ Cherokee
Thank you ehall .I'll check into that
Glock Forum
