Passenger Power Window? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Passenger Power Window?
Premium LED Lighting by VISION X, Proudly sold at ROCKRIDGBds fox ipf 2.0 racing series shocks now available at rockEngo winches available at www.rockridge4wd.com! Free shipp
Unread 05-31-2014, 08:57 PM   #1
MyJeepIsNamedCJ
Odd fact ... passenger power window will not operate via passenger switch, EXCEPT when rains or foggy (seriously!). Works OK from driver's side. Window lock/unlock switch position, no change. Rarely haul backseaters, unsure if rear wins affected. Any clue how to fix (cuz I've no plans to relo to Seattle)?
MyJeepIsNamedCJ is offline   Reply With Quote
Unread 06-01-2014, 07:41 AM   #2
wizardPC
One passenger window or all of them?
http://gunscarstech.com
Third time's the charm....
wizardPC is offline   Reply With Quote
Unread 06-01-2014, 08:25 AM   #3
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
A logical guess is that you need to find the broken wire. Use your $6-12 Volts Ohms Multi-meter to test for wire continuity, good grounds, and 12 volts where it is needed.
According to the National Shooting Sports Foundation, AR-15 sporting rifles account for nearly 20% of all U.S. firearms sales.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 06-01-2014, 10:32 AM   #4
M35A2
1995 XJ Cherokee
Or the switch has a poor connection or a corroded circuit board and the moisture/cooler air is completing a path well enough to make the switch work. The VOM will be your friend. If you don't have one, well, go get one, or, make a trip to the local pull a part, find a doner switch and try it out on your truck. Swapping parts is a valid troubleshooting tecnique, but it can get expensive
Volunteer, American Society of Military History. Come see us at http://tankland.com/
M35A2 is offline   Reply With Quote
Unread 06-03-2014, 11:18 AM   #5
MyJeepIsNamedCJ
Front pass off/on, sometimes both rear pass. All work via driver. Unemployed ... can't afford VOM/tester parts. Too bad one of y'all aren't closer to Poconos (PA) ...
Unread 06-03-2014, 11:42 AM   #6
wizardPC
I'm afraid you're going to need to replace the driver window switch pod. If you can't afford a $6 VOM i don't think you'll be able to replace that, either.
