Passenger door wont open from inside!! - JeepForum.com
post #1 of 5 Old 02-19-2013, 03:51 PM Thread Starter
mahoneyn1994
After one of my drunken buddy's yanked my handle hard from the inside, since then no one has been able to let themselves out of their passenger door
mahoneyn1994 is offline
post #2 of 5 Old 02-19-2013, 03:57 PM
KG8893
this happened on my dad's old cherokee. You gotta take the door panel off and slip the rod that attaches to the door latch back in. IIRC the handle has it's own separate spring so it won't be floppy.... I don't have a picture unfortunately. it's a childhood memory. haha
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #3 of 5 Old 02-19-2013, 03:58 PM
Green4dr
yea just take the door skin off. then the mechanism is very easy to get to
98 Green Cherokee Classic 4.0
3'' Rough Country II 33x12 bfg at
Spring Break Build thread/ makeover
http://www.jeepforum.com/forum/f22/98xj-classic-springbreak-makeover-1344754
Green4dr is offline
post #4 of 5 Old 02-19-2013, 06:49 PM
habbyguy
Errrr, don't literally do what Green4dr suggests (since the "door skin" refers to the steel, outer portion of the door). You may not even have to take off the (inner!!!) door panel - just remove the inside door handle (three screws) and gently pull it out and see if there is still a rod connected to the handle. If not, see if there's still a plastic thingamajig that lives in the hole the rod goes through - it should have a hole for the rod where it makes a 90 degree turn, and a "guide" to hold it in place just below that. If the plastic bit is broken (most commonly, the "guide" will snap off) then go to the dealer or junkyard and get some more. In a pinch, I've used some silicon tubing (that barely slides over the rod, and then barely fits through the hole in the handle mechanism). Saved me a trip, and let me put my door back together after painting the Jeep. FYI, the same clips are used on the door lock mechanism, so you can see what a good one looks like.
If the rod DOES still connect to your door handle mechanism, it's popped off the other end, and you will have to pull your interior (!) door panel off. It uses the same plastic clip, and is a little fiddly to hook up, but it's a pretty simple system.
habbyguy is offline
post #5 of 5 Old 02-20-2013, 04:11 PM
jserna
1987 YJ Wrangler
Punch your bud in the face and make him fix it!!!!! Haha just like the other responses pop the panel off and re-attach. Oh yea by the way next time go in his ride and do the same thing to his.
jserna is offline
