Part time 4WD Light..and others - JeepForum.com
post #1 of 6 Old 08-14-2002, 06:17 PM Thread Starter
sneakysnake
Question Part time 4WD Light..and others
I've only had my 1990 cherokee 4 door for a few months, so I'm still learning all about it. The light on the dash that tells you what 4 WD option you are in is STUCK in the on position..always telling me I'm in "part time 4WD. I haven't been 4 wheeling in it, but I have run it thru all the gear positions..4 low 4 high etc. Nothing changes this light, and no others come on (like 4 high).. Is this a stuck button or detent or some such thing? How do I track it down? And......is this something I can fix myself?? Thanks in advance for any help you can give the newbie.
sneakysnake is offline
post #2 of 6 Old 08-14-2002, 09:32 PM
Tomguy
2014 WK
Probably just a shorted/stuck position sensor. And there is no "4 high" light, just Part Time, and if you have Select-Track, Full Time.
Hemi, Towing & Lux
198k
Previous: 1972 Benz 280SE 4.5, 1992 XJ Cherokee Laredo, 2006 Charger R/T
Tomguy is offline
post #3 of 6 Old 08-14-2002, 11:30 PM Thread Starter
sneakysnake
Thanks Tomguy.....not sure
which I have, but my selector says... 2WD .. 4 Part Time... 4 Full Time... and 4 Low and it would appear that there are indicators for these along the left side of the dash. The "part time 4WD light is the one stuck on. and I've never seen the others..You are probably right about it being a stuck or shorted position sensor, but where is the little bugger? Is there anything I can clean , spray , adjust or thump to correct the problem?? IF I knew where to start I'd be one up on the parts guy when I call him..I'd hate to pay someone to fix this if I can do it my self. Thanks for your help!!
post #4 of 6 Old 08-15-2002, 08:38 AM
williak
The position sensor is on the front differential on top of the center disconnect. Also check your module and the vacuum lines to it.
williak is offline
post #5 of 6 Old 08-17-2002, 10:47 AM Thread Starter
sneakysnake
Thanks
Thanks Williak... That gives me a good place to start tracking it down. I will crawl under the jeep this weekend and see what there is to see.
post #6 of 6 Old 08-17-2002, 11:48 AM
CruzNlife1
CruzNlife1's Avatar
I seem to be having a vacuum theory lately check my other thread
1989 Jeep Cherokee XJ LIMITED....2door.... Auto, NP242 4x4...
1996 Ranger Supercab....
1991 Mustang LX....
VERY SOON TO BE A BRAND NEW TJ OWNER, TRYING TO LEARN AS MUCH AS POSSIBLE RIGHT NOW !!
CruzNlife1 is offline
i need off part time light coman90 XJ Cherokee Technical Forum 7 09-08-2009 10:24 PM
Part time light alhefner XJ Cherokee Technical Forum 9 01-17-2009 09:12 AM
'Part time' light out halfmoonclip XJ Cherokee Technical Forum 7 12-27-2008 01:46 PM
Part Time light on all the time? Jeremy_Cherokee XJ Cherokee Technical Forum 1 07-21-2007 10:28 AM
Part-Time 4WD light NorthernStang XJ Cherokee Technical Forum 6 01-26-2007 05:11 AM
