Quantcast part identification? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > part identification?
Old 03-27-2005, 09:44 PM   #1
mhonkieys
if anyone knows for sure what it is i'd be greatful (the part pointed out as sensor)
http://www.errordesign.com/~d0c/jp1.jpg
89 XJ 2.5L I4 TBI (121hp model)
2wd stock setup.
(not for long :)
mhonkieys is offline   Reply With Quote
Old 03-27-2005, 09:49 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Looks like the cruise control module. It's late and I'm tired, but I think that's it.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 03-27-2005, 09:53 PM   #3
mhonkieys
thanks, but nope, its a base model jeep, standard tranny only thing it has is power steering.
2wd stock setup.
(not for long :)
Old 03-27-2005, 09:59 PM   #4
Fred85
i have no idea, but i'm gonna take a stab
throttle position sensor??
Fred85 is offline   Reply With Quote
Old 03-27-2005, 10:09 PM   #5
mhonkieys
i thought it was the tps as well, but i researched it and the tps is in the rear of the intake (behind and under the rubber intake hose with "up" on it)
the only thing i've heard that might make sense is idle air control motor. but i'm unsure. i can't find a picture of said idle air control motor (which isn't the idle air control valve) so i don't know.
2wd stock setup.
(not for long :)
Old 03-28-2005, 09:19 AM   #6
mhonkieys
no one knows? *bump bump*
2wd stock setup.
(not for long :)
Old 03-28-2005, 11:07 AM   #7
CraigAllen
As a fellow 2.5 owner, I submit that that's your ISA motor (Idle Speed Adjustment). It is designed so that when you first start your engine it bumps your throttle up a bit. When you shut your engine off you should hear it retract (a series of ratcheting clicks - not too loud). Through the computer, it also works in conjuction with the A/C compressor (if equipped) and power steering pressure sensor to maintain engine idle speed when either of these kicks on.
96XJ Sport 4.0 Auto CommandTrac, Chrys. 8.25, 1-3/4" BB, WARN HS9500 winch, WARN Body Armor front & rear bumpers, tire carrier, rock sliders and transfer case skid plate. 30x9.5 BFG Mud-Terrain T/A's. As of March 10, 2011, there are 205K miles on the clock and she's still good and strong!
CraigAllen is offline   Reply With Quote
Old 03-28-2005, 03:51 PM   #8
mhonkieys
thanks crieg
2wd stock setup.
(not for long :)
Old 03-28-2005, 03:58 PM   #9
mhonkieys
thanks crieg
2wd stock setup.
(not for long :)
Old 03-28-2005, 04:43 PM   #10
CraigAllen
You're welcome!
Glock Forum
