Part/Full Time 4x4 Problem? - JeepForum.com
post #1 of 16 Old 11-19-2010, 03:28 PM Thread Starter
sixty7ss
I just bought a 2000 XJ and, being the numbskull that I am, I took the guy's word for it and didn't test the 4 wheel drive before I bought it. It seems to be working, but whether it's in 4-HIGH or 4-LOW, the instrument panel always says Part Time. Shouldn't it switch to Full Time when I shift into 4-LOW? Any ideas, suggestions, etc. would be appreciated.
Dave
sixty7ss is offline
post #2 of 16 Old 11-19-2010, 03:31 PM
theducksguts
probably a wiring issue. There should be 3 wires running from the center connector on the Transfer case. Check if it is unplugged, damaged. If there is a hookup that doesn't fit, then it was probably swapped in for the 231. Good thing is that there is a cable jumper that can be purchased to plug into the harness to convert it.
I swapped out my Full time case for a part time case. Now all I need is a jumper to get the lights to work.
The lights do nothing for the functionality of the case. It is all mechanical anyways. Not really much to worry about.
Check out my
theducksguts is offline
post #3 of 16 Old 11-19-2010, 04:07 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Dave
You're confused. It would never be full-time in 4Low. Part time 4wd means you can only use it part of the time, like when the road surface is slippery enough . Full time was a selection only available in the NP242 transfer case which allowed you to drive on hard dry surfaces all the time. I suspect you have a NP231 transfer case. What does it say on the driver's visor?
cruiser54 is offline
post #4 of 16 Old 11-19-2010, 04:14 PM
marksman1941
1989 XJ Cherokee
Exactly. I have the 242, which has the full time option. Check your tcase shifter and see if it goes 2, 4hi, 4full, n, 4lo. Full time light will only come on if you are in 4full.
If women can have a closet full of shoes, I can have a safe full of guns.
- rivalarrival
marksman1941 is offline
post #5 of 16 Old 11-19-2010, 07:17 PM
sskinner
it will only show fulltime when in hi4 4 low is part time. its should say the above the DS visor.
sskinner is offline
post #6 of 16 Old 11-19-2010, 08:07 PM
Trons
I'm going to ditto the above statements with the added statement that you wouldn't be the first person to misunderstand Jeeps use of the terms "full time" and "part time". I had a friend who had a Jeep for quite a while. He had a NP231 and when I got mine, he tried to convince me that "full time" was where I wanted to be on hill climbs, and wheelin' and "part time" was where i wanted to be when on the road during snowy days.
Luckily, Jeepforum had already convinced me of the opposite, I'm just using this as an example of how your question is fully warranted and I dare say, anybody who's not used to Jeeps labeling could be confused.
'03 TJ Rubicon
'16 KL Latitude
'91 Cherokee Laredo, Stock - Sold
'98 XJ - burned :(
Trons is offline
post #7 of 16 Old 11-19-2010, 08:42 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Mental note. The 4wd modes are "when" you can use that mode.
post #8 of 16 Old 11-21-2010, 10:12 PM Thread Starter
sixty7ss
Thanks for all the replies. I am now completely, 100% confused. Here's what I know...
* My shifter has 3 positions: 2WD, 4HI, and 4LO
* When in 4HI or 4LO, the instrument panel reads Part Time.
* The Full Time light never lights up, regardless of which gear I'm in.
What SHOULD happen? When SHOULD the Full Time light come on?
Forgive my ignorance. I'm new to Jeeps in general.
Dave
sixty7ss is offline
post #9 of 16 Old 11-21-2010, 10:18 PM
nitecop
Dave
Yours is working as it was designed to.
Your shifter would have two 4HI positions if it came with the full time/part time case (NV242). which it sounds like it does NOT have.
Without that case the full time light will not come on.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #10 of 16 Old 11-21-2010, 10:51 PM
Timo_90xj
Timo_90xj's Avatar
Dave
You have a 231 transfer case, also called command track. Your full time light should never come on, because you do not have a full time transfer case.
As already stated, the NP231 transfer case (which you have) is a part-time case, which means you should NEVER use your 4 wheel drive on dry - or even wet roads. Only ice/snow/mud/ slippery stuff like that. If you go wheeling, you can use the 4hi/4lo as needed.
In Jeep terminology, 4 full time means you can use that 4 wheel drive mode all day, anywhere, everywhere. Full time transfer cases have a "center diff" that allows different wheel speeds between front and rear axles. This makes turning easier, and also won't cause the drivetrain to bind.
Part time four wheel drive means the front and rear axles are 100% locked together inside the transfer case, thus not allowing for wheel speed differences between front/rear. On dry surface, this causes a lot of strain on the drivetrain. If you use part time 4wd on ie. dry roads at highway speeds, you might crack the transfer case or damage your axles.
***Under construction***
Timo_90xj is offline
post #11 of 16 Old 11-22-2010, 04:39 AM
hdsport
2008 WK
Dave
From what I've read, your dash light is working as designed.
In 2WD...no light
in 4WD Hi...Part Time Light
In 4WD lo...Part Time Light
= switch is OK, Plug is OK (not corroded), Wiring is OK, Dash light is OK.
Enjoy...............
hdsport is offline
post #12 of 16 Old 11-22-2010, 04:48 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Do you have the sticker on the driver side visor describing the 4wd modes?
Anyway, everything is normal. Perhaps picking up an owners manual for your Jeep would be a good idea.
post #13 of 16 Old 11-22-2010, 07:26 AM
justanotherjpr
Dave
You should not have the 'Full Time' light come on unless you have a 'Full Time' position on your transfer case.
Under no circumstances should you use 4HI or 4LO on a dry, hard roadway (Like pavement, gravel is OK) - and that is what the Part Time is meant to indicate - that you can use this position part of the time. Full Time is meant to indicate that you may use this position any time, including on bare pavement. This was an option for Cherokees but yours does not have this position - you still have the spot on the gauge cluster because they put the light on all the clusters to save on production costs.
Edit: The difference in 4HI and 4LO is gear reduction. 4LO is for slow speed if things are very muddy or snowy, a very steep, slow hill climb, or maybe pulling free a stuck vehicle. Typically, if you intend to exceed 15mph, 4HI is the best choice. Basically, you have three gears lower than your first gear which are available to you by placing the transfer case in 4LO.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #14 of 16 Old 11-22-2010, 10:17 AM
mx2times
This exact thing confused me for days as well. Thanks to everyone here I now finally get it
mx2times is offline
post #15 of 16 Old 11-23-2010, 12:30 AM Thread Starter
sixty7ss
Thank you to everyone that responded. I really appreciate you guys clearing that up for me. This forum is great! Thanks again for the help.
Dave
sixty7ss is offline
4x4 , full time , instrument panel , Part time 4 wheel drive
NP242 Transfer Case: Full Time and Part Time, What's The Difference? 89SAFARIXJ XJ Cherokee Technical Forum 62 10-27-2013 08:17 PM
transfer case problem ? please leave input, part time/full-time robdoggydog1 XJ Cherokee Technical Forum 8 11-26-2009 09:51 AM
Does Front Locker Lock on all Levels (Full-Time, Part-Time) CalebsXJ XJ Cherokee Technical Forum 4 11-09-2009 09:04 AM
part time and full time lights stay on... Dexter350k XJ Cherokee Technical Forum 2 05-21-2006 05:33 PM
