Parking shake - JeepForum.com
post #1 of 7 Old 08-02-2005, 12:44 PM Thread Starter
Schmuckingham
Parking shake
Ive got a stock 85 XJ 4x4 and i recently did a break job of both front rotors and pads( while i was changing the two front axle u joints that were busted and also put new hubs on it cause they were pretty banged up from trying to get them off). After the change the brakes seem real squishy and almost non existent. I think i have a slightly hung up caliper cause on the highway if you go to stop it will try and pull right, unless its the MC.
Also if your turning left into a parking spot and hit the breaks ever so slightly they whole front end of the Jeep shudders and feels like my break are binding up.
Any suggestions on what it might be?
Mike
1997 Honda Accord LX-T-300WHP/315FT/LBS
1985 XJ-Reliable Greatness
1991 Eagle Talon TSI-SOLD
Schmuckingham is offline
post #2 of 7 Old 08-02-2005, 02:36 PM
meat12
meat12's Avatar
If I were you, and if you are planning on keeping it for a while, well regardless for safety reasons, I would replace the calipers. They are relativly inexpensive and will most likely solve your problem. The same situation happened with mine, a seal or something got ruined in the piston when I pressed it back to get it on the rotor.
Replace calipers and bleed the lines thoroughly.
91XJ- NP231, 31x10.5 MTR's, 15x8 soft 8's, BB, K&N intake, Cherry bomb exaust, CB, Stereo mods, fog lights, custom Aluminum body work to cover rust.
Rember: If they dont find you handsome, at least they will find you handy!
meat12 is offline
post #3 of 7 Old 08-02-2005, 03:14 PM
Friar_Nurgle
Friar_Nurgle's Avatar
Grab some new hoses to go with those new calipers while your at it...
...but if you're cheap and broke like some/most of the people here, try lubing the caliper slide pins (or whatever they are called) and bleeding what you have first and see if that helps.
Good luck
95 XJ Green & Black two tone up to the body line (pics coming soon when we get the damn digital camera fixed... damn cats)
4 Door Plain Jane
4.0 HO - Manual - Comand track
6x9 sound bar speaker mod
Friar_Nurgle is offline
post #4 of 7 Old 08-02-2005, 03:22 PM Thread Starter
Schmuckingham
Ill probably will get new calipers here in the soon near future but i cant help but think its the damn MC. Cause the pedal is acting real weird. Like right after i did the brakes you could go to stop and the pedal would go all the way to the floor and my brake light would pop on. Then after you starting going again either the light would go off or you would pump the brakes and they would get better eventually.
Freakin weird
Mike
post #5 of 7 Old 08-02-2005, 03:58 PM
meat12
meat12's Avatar
If you pushed the pedal to the floor when you blead the breaks, you may have damaged some of the seals in the master cylinder. They get brittle and wear, and when you put the pedal down they can disinigrate. That may be your problem. However that still does not explain the pulling to one side when breaking, it just explains the poor pedal feel. I would still replace the calipers, since all of the other stuff is new. If replacing the calipers and rebleading the brakes does not fix the problem, then you know it is the master cylinder.
To others that read this, if I am incorrect in my thinking please correct me.
meat12 is offline
post #6 of 7 Old 08-02-2005, 04:54 PM
conrasm
conrasm's Avatar
I totally agree. The MC shouldn't cause a difference in the pressure to either side, just the squishy feeling. The brake hoses can definitely make the car pull to one side. Like he said, you can damage the seals in the MC when you bleed the breaks. I usually put a brick or 2x4 under the pedal so it doesn't bottom out. When I changed the brake lines for my lift, I just cracked open the bleeders and let 'em run until the air was out. Takes a little longer, but still works. Sounds like you may end up replacing most of the brake components, but thank god for the aftermarket parts stores. You can't beat their prices.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #7 of 7 Old 08-02-2005, 07:51 PM Thread Starter
Schmuckingham
Yea gravity bleeding is the way to go, but it does take time. im just gonna replace the whole front system for now. calipers, lines, and MC.
Mike
shake bomba6213 XJ Cherokee Technical Forum 5 11-21-2008 12:37 PM
Parking lights in back work,Blinkers work,Front parking lights dont??? argh ChaoticBastard XJ Cherokee Technical Forum 2 03-23-2006 10:51 PM
shake pojeep96 XJ Cherokee Technical Forum 4 02-08-2006 01:53 PM
For God Shake Grdaemon XJ Cherokee Technical Forum 1 11-13-2004 06:06 PM
High Speed Shake (THE DEATH SHAKE) skippythespy XJ Cherokee Technical Forum 4 03-10-2004 10:01 PM
