Quantcast Parking Brake - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Parking Brake
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 09-07-2006, 06:53 PM   #1
CherokeeDude
Parking Brake
How do I tighten my parking brake? Mine is kind of loose & I need to tighten it up. Thanks!
1985 Jeep Cherokee
4 Door
4x4, NP207
AMC 2.5 Liter, 4 Cylinder
T4, 4 Speed Manual
CherokeeDude is offline   Reply With Quote
Old 09-07-2006, 09:39 PM   #2
CherokeeDude
Bump......
1985 Jeep Cherokee
4 Door
4x4, NP207
T4, 4 Speed Manual
Old 09-07-2006, 09:44 PM   #3
djshortsleeve
Loose? What do you mean?
1999 XJ Sport 4.0 4wd 4 door
140k miles
Desert Sand XJ club President
djshortsleeve is offline   Reply With Quote
Old 09-07-2006, 09:46 PM   #4
ChewyXJ
nom nom nom
ChewyXJ's Avatar
Climb underneath your baby, look above your rear driveshaft and you'll see two cables coming from the rear. Where these cables come together you'll see a bracket. On the rear side of the bracket you'll see a nut (don't remember the size for sure but I think its either 13 or 14 mm). This is your parking brake adjusting nut. Tighten/loosen this nut till you get around 6 clicks out of your parking brake handle.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline   Reply With Quote
Old 09-07-2006, 09:49 PM   #5
CherokeeDude
Okay, I will do that. Thanks!
1985 Jeep Cherokee
4 Door
4x4, NP207
T4, 4 Speed Manual
Old 09-07-2006, 10:13 PM   #6
ki1022
Also, to adjust individual sides, look on the back of your drum brakes. There should be a rubber plug near the bottom. Pull that off and you will see your star-wheel. Stick a screwdriver in the hole and turn this wheel to adjust the brake.
94' XJ
ki1022 is offline   Reply With Quote
Old 09-08-2006, 01:04 PM   #7
AZ Jeff
Proper parking brake adjustment always starts with adjusting the individual wheels FIRST, and THEN the equalizer assembly.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Glock Forum
