p1494 code - JeepForum.com
post #1 of 3 Old 06-29-2009, 03:40 PM Thread Starter
mikemm
p1494 code
Hello all....does anyone out there know why the display on the scanner tool for a p1494 code reads''''manuf. control auxiliary emission controls"? It is a 2000 cherokee I6. thanks mike
mikemm is offline
post #2 of 3 Old 06-29-2009, 03:44 PM
LeftOfCenterXJ
1988 XJ Cherokee
P1494 Leak Detection Pump (LDP) Switch or Mechanical Fault
1. Check to make sure there is manifold vacuum to the LDP. The LDP is located in the engine compartment on the passenger side, near the A/C accumulator.
2. If vacuum is present at the pump, gain access to the LDP electrical connector.
3. Locate the Dark Green/Orange wire. Test voltage on this circuit, it should be battery voltage with the engine running.
4. With the connector plugged in to the LDP, ground the White/Dark Green wire.
5. Attach a test light to battery ground. Probe the last wire on the connector which is White/Orange.
6. Start the engine. Remove the ground and reapply the ground several times. During this sequence of grounding and un-grounding the circuit, the test light should turn on and off. If it does not, it is a bad LDP.
It's most likely either a disconnected or leaking vacuum hose or the LDP (Leak Detection Pump) itself.
"Too weird to live, too rare to die"
2000 XJ Silver, 3", 31's DD
88 XJ Blue, 4.5", 33's, Project
Originally Posted by Juju
It makes your trolling more credible to be grammatically correct. Lets everyone know you're a legitimate troll, not just one of those poser trolls.
LeftOfCenterXJ is offline
post #3 of 3 Old 06-29-2009, 03:51 PM Thread Starter
mikemm
thanks alot. turns out the rubber 90 at the intake manifold popped off. I think it did it when it misfired/hiccuppped when i started it once.
mikemm is offline
Engine Code: P1494 00xj54 XJ Cherokee Technical Forum 48 08-17-2016 07:33 AM
code p1494 question jersey_jim XJ Cherokee Technical Forum 3 11-16-2009 09:40 PM
2000 jeep troubleshhoting code P1494 info ? lonewolf5347 XJ Cherokee Technical Forum 1 09-29-2009 01:55 PM
Check Engine Code P1494 typer1122 XJ Cherokee Technical Forum 1 06-23-2009 02:12 PM
Check engine light on, Code is P1494 ??? Elohim1 XJ Cherokee Technical Forum 2 01-09-2005 03:23 PM
