P0204 - JeepForum.com
post #1 of 9 Old 04-21-2008, 05:53 PM Thread Starter
ProjectXJ00
P0204
Hey guys
Over the past months I've had a reoccurring problem with my 2000 XJ. About a month ago I got a check engine light. My brother is a VW/Subaru nut so hes got a code reader. He scanned my car...P0204 and P0304 come up. The exhaust reeked like fuel and he said that for some reason the Cyl. 4 injector was dumping too much fuel and therefore causing Cyl. 4 to also missfire, this also explained the fuel smell in the exhaust.
I took the car to the dealer to have them change out the injector. They fixed the problem and it didn't come back. Just yesterday, a month after it was fixed, I was driving home and a CEL popped up. I got home, scanned it, and it was P0204, the same problem.
Any idea what the problem is?
Thanks in advance.
ProjectXJ00 is offline
post #2 of 9 Old 04-21-2008, 05:58 PM
Smittie
P0204 (M) Injector #4 Control Circuit
Injector #4 or INJ 4 injector bank output driver stage does not respond properly to the control signal.
Not much of a contribution but...
Smittie
Smittie is offline
post #3 of 9 Old 04-21-2008, 06:05 PM
01sherman
i was having the same problem but with #6 i replaced the inj but never the coil and now i have codes p0700 and it doesnt misfire but i cant also clear the code i have a post up on it
01sherman is offline
post #4 of 9 Old 04-21-2008, 10:23 PM Thread Starter
ProjectXJ00
thanks for the responses, anyone else?
post #5 of 9 Old 04-22-2008, 10:18 AM Thread Starter
ProjectXJ00
up to the top
post #6 of 9 Old 04-22-2008, 11:04 AM
dvlscoupe
Use the scan tool to moniter the injecter pulse for that one (if you can with that scan tool) or use a meter or test light to watch the voltage. It may be shorting in the harness or getting a signal from the modul to stay open to long. It could also be getting to much voltage and getting stuck on. If it keeps happening to much fuel can wash out the cylinder, and break down oil and cause havoc on the bottom end.
dvlscoupe is offline
post #7 of 9 Old 04-22-2008, 11:06 AM
dvlscoupe
Another easy way to jus check that injecter is swap it's position with a known good one on the cylinder and see if it's still effecting cyl# 4 or if it transfers to the cylinder you moved it to. Then you'll know it's an injector and not a harness/computer issue.
post #8 of 9 Old 04-22-2008, 04:57 PM Thread Starter
ProjectXJ00
Very good call, thanks so much for the information.
post #9 of 9 Old 06-24-2012, 10:15 PM
Vici0usX
Revive! So I did the above mentioned and the problem persists, so this would indicate a problem with the wiring or computer? Best way to test?
98 TJ Sport 4.0L
Vici0usX is offline
P0204 Injector Failure Code then went away? jeep-noob XJ Cherokee Technical Forum 0 09-19-2009 04:16 PM
P0204 Code 9Classic8 XJ Cherokee Technical Forum 6 03-07-2009 01:04 PM
