P0131 - JeepForum.com
post #1 of 3 Old 03-31-2014, 05:56 PM Thread Starter
Evan1989
P0131- oxygen sensor bad or something else?
Hey all.
I have a 1999 cherokee around 100k miles. CEL displays P0131 which is 02 sensor bank1 sensor 1 voltage low. This sensor is located before catalytic converter.
Since the voltage is low, I believe this means it is running lean which results in too much oxygen being let it in.
At times, the car runs a bit rough at idle.
I have located the sensor but it seems the plug goes up to the engine. My hand cant get in there to unplug it if I wanted to change it. Any Ideas?
Also I just want to know what the other issues can be besides the 02 sensor being faulty.
I do not see enough of the wire to see if there is a short. Where is the connector that goes to the engine compartment located?
Any ideas and experience, I would appreciate.
-Evan
Evan1989 is offline
post #2 of 3 Old 03-31-2014, 06:24 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Either a faulty O2 sensor, O2 sensor wire harness issues, or a cracked exhaust manifold. Cracked exhaust manifolds are very common.
P0131 JEEP O2 Sensor Circuit Low Bank 1 Sensor 1
Symptoms
- Check Engine Light ON
- High Fuel Consumption
- Excessive Smoke from Exhaust
Possible causes
- Faulty Front Heated Oxygen Sensor Bank 1
- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Faulty fuel injectors
- Intake air leaks
- Exhaust gas leaks
CJ7-Tim is offline
post #3 of 3 Old 03-31-2014, 10:11 PM Thread Starter
Evan1989
thanks for the reply.. how would i check if there is a short if I cant even get my hand up enough to disconnect the sensor plug and see any of the other wires? Is there a way to access it from the the hood area
Evan1989 is offline
