Overheats offroading - Page 2 - JeepForum.com
post #16 of 18 Old 06-26-2012, 10:55 PM Thread Starter
98GooseXJ14
1997 XJ Cherokee
That is what my current 97 sits at, when I meant overheating I meant it was pegged at 260 and boiling.
2000 Jeep Cherokee XJ 95k miles - Sold
1998 Jeep Cherokee XJ 160k miles - Killed/Sold
1997 Cherokee XJ 173k miles 5spd Killed/Sold
98GooseXJ14 is offline
post #17 of 18 Old 06-27-2012, 03:45 AM
Geoff1965
1993 XJ Cherokee
Mine had the same symptoms. I tried everything except new radiator.
The water pump was new but I took it off to inspect anyway. I checked the cylinder wall immediately behind the pump and it had been scored by a previous owners water pump failure. It hadnt cut thru the cylinder wall but it had removed material from the cylinder wall inside the water jacket. I found a whole lot of little balls of rusty matter about the size of a 3/16" ball bearing. There were hundreds of them. We cleaned them out, refitted pump and new thermostat and rad. cap. The car ran cooler but not 100%.
If the above list doesnt fix yours maybe you have a problem similar to mine.
Geoff1965 is offline
post #18 of 18 Old 06-27-2012, 09:59 AM
BillB7581
My 2000 Sport runs to the left of 210 at all times now.
Radiator was 2 year old plastic tank replacement.
Replaced Water pump, thermostat, bottom hose and temp sensor (broke trying to unplug it) with new parts from Carquest. Gave it a good flush and refill with 50/50 premix and it runs below 210 on the gauge with a missing fan shroud (broke doing the radiator). Cured my random misfiring problem also.
I need to get my reader back from the guy who borrowed it to see exactly what temp the sender is picking up.
BillB7581 is offline
overheating
overheats Phantomx2 XJ Cherokee Technical Forum 5 08-17-2011 09:45 AM
XJ Overheats w/AC On scouperacer1994 XJ Cherokee Technical Forum 4 08-08-2010 08:50 PM
4.0 still overheats after new parts sterfry2004 XJ Cherokee Technical Forum 25 09-30-2009 12:33 AM
Yet Another Cherokee Overheats! uletek XJ Cherokee Technical Forum 18 09-15-2009 12:12 AM
XJ overheats only when kongpheng XJ Cherokee Technical Forum 13 09-05-2008 04:26 AM
