Overheating Problem after radiator flush - JeepForum.com
post #1 of 11 Old 11-22-2011, 11:32 PM Thread Starter
Dan69
Maybe someone can help me out here. I flushed the radiator on my 2003 cherokee 4.0 and filled it with new fluid. After the back flush and fill a couple of days later it started overheating sometimes (not all the time). It's overheated about 4 times this month. it never had this happen untill after the backflush and fill.
This is what I did originally:
drained the radiator
backflushed the system and drained it again
refilled with anti-freeze
let it warm up and cool down
top it off again
top it off again
It was full after the last warm up, but three days later it overheated. The overflow bottle was completely full after the overheat like it backed a lot of fluid into it. When it cooled off it pulled the fluid back into the radiator. No problems for a few days and then it did it again.
I'm at a loss on why this is happening. It seems like I did something maybe when I flushed the system, but I can't think of anything that would cause this. Any help would be greatly appreciated
Dan69 is offline
post #2 of 11 Old 11-22-2011, 11:50 PM
Reptile
1991 XJ Cherokee
What coolant/water mixture did you use? Sounds like a bad rad cap.
Reptile is offline
post #3 of 11 Old 11-23-2011, 01:27 AM Thread Starter
Dan69
i used a 50/50 mix, but didn't use the Dexcool. if the radiator cap was bad, could it bypass enough coolant into the overflow tank to make it overheat?
Dan69 is offline
post #4 of 11 Old 11-23-2011, 01:28 AM
matt62485
im assuming this is a WJ and not an XJ b/c it's an 03, but I know the late model XJ's with the 0331 heads are prone to cracking/overheating issues, not sure if an 03 GC would have the same head or not. any water in the oil?
make sure theres nothing some crap in the thermostat. radiator caps are a common issue too.
[]IIIIII[]
matt62485 is offline
post #5 of 11 Old 11-23-2011, 07:25 AM
jjshbetz11
Does your thermostat have the little hole in it so you don't have to burp the system? If not burp it.
sent from a flat black thingie
R.I.P 96 xj aka. War Queen
Hello 2000xj
jjshbetz11 is offline
post #6 of 11 Old 11-23-2011, 08:21 AM
bobbo_xj
double check that your electric fan is connected and working
2001 XJ Sport, 173k mi.
bobbo_xj is offline
post #7 of 11 Old 11-23-2011, 08:37 AM
FairlanePhil
FairlanePhil's Avatar
03 Cherokee?
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
post #8 of 11 Old 11-23-2011, 09:08 AM
bobbo_xj
Originally Posted by FairlanePhil View Post
03 Cherokee?
Maybe OP is from powder springs, china... Or we just happily entered a parallel universe where XJ's are still being made in the states.
bobbo_xj is offline
post #9 of 11 Old 11-23-2011, 10:37 AM
Reptile
1991 XJ Cherokee
I hope you didn't use Dexcool, but that wouldn't cause the problem. No the rad cap builds up pressure and increases the boilling point of the coolant. If the cap is bad, then boiling makes it overheat and overflow through the cap.
I'm going with parallel universe. That's the most logical explanation...
Reptile is offline
post #10 of 11 Old 11-23-2011, 09:55 PM
FairlanePhil
post #11 of 11 Old 11-23-2011, 11:04 PM
Azzy
While it is running, squeeze the upper rad hose. Watch your fingers. You will hear any air coming out of the system, and going into the overflow tank.
The system is supposed to self burp, but I havent seen one do that yet.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
Best way to do a radiator flush critmuncy99 XJ Cherokee Technical Forum 7 08-29-2010 10:20 PM
Overheating - Rad Flush? riptide XJ Cherokee Technical Forum 14 07-30-2009 10:00 PM
How to Flush a Radiator When There is No Cap? MichMarine78 XJ Cherokee Technical Forum 1 11-27-2008 03:44 PM
Radiator flush dert XJ Cherokee Technical Forum 2 09-15-2008 08:23 AM
how to flush the radiator hlgomez73 XJ Cherokee Technical Forum 1 11-20-2002 09:04 PM
