overheating only when a/c is on - JeepForum.com
post #1 of 16 Old 06-29-2012, 06:12 PM Thread Starter
michaelleegarre
i have a 98 xj with the 4.0 temp stays just a little above the 210 mark but when i turn on the a/c after a few miles it goes to 260 ill pull over let it set for the most 5 min. with the key on and it will drop back down like the thermostat opens if i drive with no ac its fine
replaced the thermostat and radiator cap fans are running eater pump should be fine it only does it with a/c on please help!!!
Michael Garrett
1987 YJ - sold, 1995 ZJ - sold, 1998 XJ - sold, 2000 TJ
michaelleegarre is offline
post #2 of 16 Old 06-29-2012, 06:17 PM
Paradise XJ
1988 MJ Comanche
Is your e-fan working?? The auxillary fan should come on at about 218-220F. If it's not working the A/C puts a load on the engine that the mechanical fan can't handle.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #3 of 16 Old 06-29-2012, 06:19 PM Thread Starter
michaelleegarre
yes the e fan is running
Michael Garrett
post #4 of 16 Old 06-29-2012, 06:21 PM Thread Starter
michaelleegarre
after hot the temp drops like the thermostat opens up but I just replaced it today
Michael Garrett
post #5 of 16 Old 06-29-2012, 06:40 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Not all new parts are good parts. Cheap parts are cheap for a reason.
Overheating can be caused by anything that decreases the cooling system’s ability to absorb, transport, and dissipate heat, such as a low coolant level, loss of coolant (through internal or external leaks), poor heat conductivity inside the engine because of accumulated mineral deposits in the water jackets or radiator, a defective thermostat that doesn’t open, poor airflow through the radiator, a slipping fan clutch, an inoperative electric cooling fan, a collapsed lower radiator hose, an eroded or loose water pump impeller or even a defective radiator cap.
The cooling system is a group of related parts that depend on proper function from each of its component parts to keep the engine cool. Service the cooling system and replace any under-performing or suspected weak parts. Any component part of the cooling system that is not fully doing its job will stress the others and your cooling system will overheat. The most important maintenance item is to flush and refill the coolant periodically. Coolant should be replaced every 36,000 miles or every three years. Anti-freeze has a number of additives that are designed to prevent corrosion in the cooling system, but they have a limited life span. The corrosion causes scale that eventually builds up and begins to clog the thin flat tubes in the radiator and heater core, causing the engine to eventually overheat.
-Use a flushing/cleaning solution and then drain and fill the radiator with a fresh 50/50 coolant and water mix. With a neglected cooling system you may have to flush several times.
-Inspect the radiator for mud/bugs/grass clogging the outside and mineral deposits clogging the inside. Clean or replace as needed.
-Replace the thermostat with a STANT or Robertshaw 195* thermostat. Cheap thermostats are cheap for a reason.
-Replace the radiator cap if your Jeep has one. An old worn out cap will allow boil overs and/or allow the coolant flash over into to steam. You will see the coolant temps suddenly jump from 210* to the Red Zone and back to 210* if your radiator cap is weak.
-Inspect/test or replace the mechanical fan clutch. A worn fan clutch will allow temperature creep at stoplights, in heavy traffic, and on the 4x4 trails. A fan clutch that “looks” OK is not the same as working OK.
-Inspect the electric cooling fan and the fan relay. Apply 12 volts and make sure the fan runs. Exchange the cooling fan relay with one of the others similar relays. Confirm that the e-fan starts when engine temps reach 215-218*. Repair or replace the fan or relay as needed.
-Inspect/test or replace the coolant temperature sensor that activates the e-fan.
-Replace the water pump. The pumping fins can deteriorate over time and the pump will not flow enough coolant to keep the temps under control.
-Inspect/replace the radiator hoses. Make sure the coiled wire is installed in the lower hose.
If you have covered all the points listed above and still have overheating issues, inspect the head for cracks and head gasket for leaks. Exhaust gasses entering the coolant can raise the temperature of the coolant or cause steam pockets in the coolant that will temporarily block the flow of coolant
Read more about cooling systems here –
www.offroaders.com/tech/engine-overheating.htm
www.familycar.com/classroom/coolingsystem.htm
CJ7-Tim is offline
post #6 of 16 Old 06-29-2012, 06:50 PM Thread Starter
michaelleegarre
also it is boiling in the overflow
Michael Garrett
post #7 of 16 Old 06-29-2012, 08:15 PM Thread Starter
michaelleegarre
just went out to try to figure out the problem after a few min working in the dark i noticed my manifold was glowing red this problem is getting bigger
Michael Garrett
post #8 of 16 Old 06-30-2012, 12:09 AM
Reptile
1991 XJ Cherokee
I can't agree more. Went through 2 new thermostats to find a good one just not so long ago. Should I had known that, I wouldn't have changed the water pump and a bunch of other stuff in the process... Cheap parts may end up being outrageously expensive.
Reptile is offline
post #9 of 16 Old 06-30-2012, 08:19 AM
ironman2427
1997 XJ Cherokee
Sounds like a plugged catalytic converter. I'd likely start there.
"When you try to put 300 horsepower in a car designed for 100, you learn what development means," --Carroll Shelby
ironman2427 is offline
post #10 of 16 Old 06-30-2012, 12:35 PM Thread Starter
michaelleegarre
looks to have no cat..... this morning i took the thermostat back out put it back together with out one so i could drive it to get a replacement and it did not overheat so i guessing this was the problem.... maybe?
Michael Garrett
post #11 of 16 Old 06-30-2012, 04:29 PM
SpideYJeep
Like CJ7Tim states, could be bad new stock Tstat. If the Tstat is in the closed position, put in boiling water and see if it opens. If it doesn't, problem confirmed.
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #12 of 16 Old 03-24-2016, 07:41 PM
grammy
I have a 1992 jeep Cherokee XJ 4.0 that over heats when I turn on the A/C
I have replaced the thermostat,radiator,condenser,fan cluch,top and bottom hoses,shroud and belt and front exhaust pipe does not have a cat convter.
I have let it idle for up to an hour with the A/C on stays at 180 deg.
As soon as I start to drive with in a few miles the temp. starts to clime even if I turn the A/C off still doesn't cool off because it heats up to fast have to pull over and let it cool
as long as I don't turn the A/C it won't over heat again
I don't know what else to fix or replace please help
Thank You
Debbie
grammy is offline
post #13 of 16 Old 03-24-2016, 08:00 PM
grammy
Thank You
Debbie
grammy is offline
post #14 of 16 Old 07-27-2016, 06:49 AM
bryaninphx1
Xj Battling high freeway temps
Originally Posted by grammy View Post
I have a 1992 jeep Cherokee XJ 4.0 that over heats when I turn on the A/C - as long as I don't turn the A/C it won't over heat again
Thank You
Debbie
I have the exact same issue that I'm battling on my "new" used '93 XJ 4.0. I know that being 113 in AZ doesn't help right now, but if I drive around the town with no a/c, it's fine. Once I hop on the highway, the stock gauge hits about 220 and the a/c will cause it to climb to (what shows) 240+ and I think those temps are causing my NOX to be too high and has me failing emissions. Did plugs, cap and fuel filter yesterday, and going to a 180 degree thermo today (not sure if that'll do anything but it's cheap, so why not).
bryaninphx1 is offline
post #15 of 16 Old 07-28-2016, 10:12 AM
getterdun
Suggest you search Google for "cherokee xj overheats when ac on" as this may give you some more ideas for things to check.
getterdun is offline
overheating
xj overheating skimsurf XJ Cherokee Technical Forum 2 01-24-2011 04:53 PM
Overheating!!!! help spacemanspiff XJ Cherokee Technical Forum 9 11-11-2009 10:18 AM
95 XJ overheating ballzac86 XJ Cherokee Technical Forum 3 03-11-2007 07:15 PM
Overheating? RedneckOmega XJ Cherokee Technical Forum 3 02-12-2007 01:33 AM
overheating? 88wagon XJ Cherokee Technical Forum 4 11-14-2006 08:08 PM
