overheating - JeepForum.com
post #1 of 6 Old 06-16-2012, 03:00 PM Thread Starter
empty__pockets
overheating
1998 cherokee limited 4.0. Blew the upper rd hose and got hot. Replaced hose and thermostat. Still ran hot @ 215 to 230 around town. Hit 260 pulling a grade. Relpaced water pump. Same problem. At idle it boils over as if no circulation. Slight rattle in engine when oil heats up. Bad bearing?
empty__pockets is offline
post #2 of 6 Old 06-16-2012, 03:04 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Probably not a bearing.
Overheating cooling system
Overheating can be caused by anything that decreases the cooling system’s ability to absorb, transport, and dissipate heat, such as a low coolant level, loss of coolant (through internal or external leaks), poor heat conductivity inside the engine because of accumulated mineral deposits in the water jackets or radiator, a defective thermostat that doesn’t open, poor airflow through the radiator, a slipping fan clutch, an inoperative electric cooling fan, a collapsed lower radiator hose, an eroded or loose water pump impeller or even a defective radiator cap.
The cooling system is a group of related parts that depend on proper function from each of its component parts to keep the engine cool. Service the cooling system and replace any under-performing or suspected weak parts. Any component part of the cooling system that is not fully doing its job will stress the others and your cooling system will overheat. The most important maintenance item is to flush and refill the coolant periodically. Coolant should be replaced every 36,000 miles or every three years. Anti-freeze has a number of additives that are designed to prevent corrosion in the cooling system, but they have a limited life span. The corrosion causes scale that eventually builds up and begins to clog the thin flat tubes in the radiator and heater core, causing the engine to eventually overheat.
-Use a flushing/cleaning solution and then drain and fill the radiator with a fresh 50/50 coolant and water mix. With a neglected cooling system you may have to flush several times.
-Inspect the radiator for mud/bugs/grass clogging the outside and mineral deposits clogging the inside. Clean or replace as needed.
-Replace the thermostat with a STANT or Robertshaw 195* thermostat. Cheap thermostats are cheap for a reason.
-Replace the radiator cap if your Jeep has one. An old worn out cap will allow boil overs and/or allow the coolant flash over into to steam. You will see the coolant temps suddenly jump from 210* to the Red Zone and back to 210* if your radiator cap is weak.
-Inspect/test or replace the mechanical fan clutch. A worn fan clutch will allow temperature creep at stoplights, in heavy traffic, and on the 4x4 trails. A fan clutch that “looks” OK is not the same as working OK.
-Inspect the electric cooling fan and the fan relay. Apply 12 volts and make sure the fan runs. Exchange the cooling fan relay with one of the others similar relays. Confirm that the e-fan starts when engine temps reach 215-218*. Repair or replace the fan or relay as needed.
-Inspect/test or replace the coolant temperature sensor that activates the e-fan.
-Replace the water pump. The pumping fins can deteriorate over time and the pump will not flow enough coolant to keep the temps under control.
-Inspect/replace the radiator hoses. Make sure the coiled wire is installed in the lower hose.
If you have covered all the points listed above and still have overheating issues, inspect the head for cracks and head gasket for leaks. Exhaust gasses entering the coolant can raise the temperature of the coolant or cause steam pockets in the coolant that will temporarily block the flow of coolant
Read more about cooling systems here –
www.offroaders.com/tech/engine-overheating.htm
www.familycar.com/classroom/coolingsystem.htm
CJ7-Tim is offline
post #3 of 6 Old 06-16-2012, 03:07 PM
n5xl
What he said...
99TJ,AX15,2"ACOS,33BFGKM2
99XJ,AW4,2"OME,JKSShortArms
98XJ,AW4,3"ACOS/Shackles/AASYE/TomWoodsDS
n5xl is offline
post #4 of 6 Old 06-29-2012, 05:40 AM Thread Starter
empty__pockets
New fan clutch, thermostat, water pump, replaced head gasket, radiator not clogged. Exhaust header temp @ #1 cyl 450 degrees. 2 trough 6 250 degrees. Any ideas? Wrist pin?
post #5 of 6 Old 06-29-2012, 06:02 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Radiator can have flow issues even though they may appear to be okay. And be sure that your new radiator cap is 16 pounds.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 6 Old 06-29-2012, 06:14 AM
Kalali
What is your oil pressure at warm idle? I'd run compression and cylinder leak down tests to further isolate the root cause.
Kalali is offline
overheating
Overheating help VCUcherokeeVFTT XJ Cherokee Technical Forum 3 08-05-2010 09:28 PM
please help overheating Tearm XJ Cherokee Technical Forum 6 07-24-2010 02:49 PM
88 XJ overheating Mazdarx XJ Cherokee Technical Forum 11 05-16-2007 02:34 AM
95 XJ overheating ballzac86 XJ Cherokee Technical Forum 3 03-11-2007 07:15 PM
Overheating? RedneckOmega XJ Cherokee Technical Forum 3 02-12-2007 01:33 AM
