Overheat with no leaks, or bubbling, wits end - JeepForum.com
post #1 of 2 Old 07-28-2013, 01:30 PM Thread Starter
MattyIce20
2003 XJ Cherokee
Hey, I'm new so if I've posted wrong or in the wrong spot I apologize. Last night, Jeep rough started, once got going, made it about a mile and saw the temp gauge was maxed out, pulled off, car stayed hot with engine off, took the risk, drove home anyway, had no issues.
Car was off for 12 hours, when I turned key to 2 hole to see gauges, still showed temp 3/4 way up, still reading hot enengine after 12 hours
Replaced Thermostat(yes I did it right) and still gets overheated like crazy
What would you all suggest? I've heard temperature sensor could be culprit because I had a hard start last night, and a hard start this morning(very rough) before attempting to change thermostat
03 Grand Cherokee I6 4.0 L 4x4
MattyIce20 is offline
post #2 of 2 Old 07-28-2013, 04:15 PM
Glavus
If you drove it home with the temp gauge maxed out and nothing happened, then it's your temperature sensor for sure. It threads right into you thermostat housing..
Normally driving over heated would cause all kinds of havoc. Clouds of steam, and a massive coolant/oil puddle under the engine.
PS: For future reference, don't 'risk' it if you think your over heating. You'll end up having to put in a whole new engine..
Glavus is offline
