Quantcast overheat - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > overheat
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 07-11-2007, 09:55 PM   #1
WILSONRIVERFISH
overheat
Jeep drives fine moving but when parked and idiling yesterday the temp went up almost full high temp. I shut it off waited for it to cool down and then thought i would see if driving it helped well it did the temp went down real low and all was fine. Im wondering if the overflow bottle was overfilled? also the top radiator hose was as hard as a rock. Im kind of thinking that the t-stat got stuck closed and help for this newb would be great
1990 cherokee 4.0l I6
191k
WILSONRIVERFISH is offline   Reply With Quote
Old 07-11-2007, 10:02 PM   #2
cygnus58
1988 XJ Cherokee
maybe your electric fan isn't working.
if it seems fine at other than idle, and the ambient temp was in the 90's. it will need the electric fan to work after a few minutes of idle.
Love that Renix. But then, I loved DOS too..
cygnus58 is offline   Reply With Quote
Old 07-11-2007, 10:07 PM   #3
WILSONRIVERFISH
the fan is turning and doing so fast. It was almost 102 degrees yesterday.
191k
Old 07-11-2007, 10:08 PM   #4
curtjames37
Could be the fan clutch on the mech fan.
curtjames37 is offline   Reply With Quote
Old 07-11-2007, 10:13 PM   #5
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
If the top hose was hard as a rock then you may want to look into a new thermostat. 195* one.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 07-11-2007, 10:17 PM   #6
NYCXJ90
1990 XJ Cherokee
have you recently added coolant? if so did you burp the system? check to see if your coolant pressure bottle's cap is on tight and not leaking or cracked. any loss of pressure and the closed system is near useless at idle.
just to be clear... the electrical fan (drivers side) is kicking on normally? (usually at around 210-220*) check it with the AC/ Defroster off. If it's not coming on it could be the temp sensor in the radiator. There's a way to test the fan clutch on the mechanical fan, run a search, should come up.
if you determine both fans are functioning correctly then you have a flow problem.
check for weeping/moisture around the bottom of the waterpump, if it's leaky you need a new pump and might as well throw in a new t-stat.
'90 XJ Laredo /33"X12.5" Retreads/ RE 3.5" Super Ride
NYPD Jeep Club Member #2
Marine Corps Jeep Club Member #3
So I tell the swampdonkey to sock it before I give her a trunky in the tradesman's entrance and I have her lick me yardballs.
NYCXJ90 is offline   Reply With Quote
Old 07-11-2007, 10:24 PM   #7
pgdyk
1988 XJ Cherokee
Could also be your guage, if it went to full high temp, coolant would be overboard, right?
pgdyk is offline   Reply With Quote
Old 07-11-2007, 10:26 PM   #8
WILSONRIVERFISH
ok I didnt know about the second fan on drivers side! Also im thinking there is pressure being released
191k
Old 07-11-2007, 10:30 PM   #9
curtjames37
If it's not holding pressure then that is most likely your problem. Closely inspect the cap/pressure bottle for cracks or leaks and replace if necessary.
You can also try burping the system:
Old 07-11-2007, 10:35 PM   #10
WILSONRIVERFISH
yeah coolant was spilling out! It was hot but went down real fast after just a little driving and some lead foot action. It was only idiling maybe 5-10 minutes. I will inspect the cap and hoses, replace the t-stat, water pump and maybe even replace the top and bottom radiator hose. Or should I move to the open system?
191k
Old 07-11-2007, 10:55 PM   #11
pgdyk
1988 XJ Cherokee
Well before you go spend a fortune and slap on a bunch of parts, try and find the root of the problem. Test the electric fan like stated before, If you are sitting there idleing and it is overheating, it may be an airflow problem, your radiator could be clogged with debris, mud, leaves, grease, etc, hose it down gently. Also, do you have a fan shroud? The plastic cover that protects yourself from losing a hand to the mech. fan, it also directs air through the radiator, instead of around it.
Old 07-11-2007, 10:57 PM   #12
WILSONRIVERFISH
nope the fan shroud is gone!
If possible and if you know of a link to but a new one give it up otherwise ill search around for a junkyard that has one.;
191k
Old 07-11-2007, 11:06 PM   #13
pgdyk
1988 XJ Cherokee
My girlfriends 89 xj overheats while idleing for even just a minute at the drive-through without a shroud, its impossible to take out in rush-hour. It's fine and dandy on the freeway. I would look around a few junkyards, if no luck, you may have some luck with a shroud from another jeep, maybe a cj or something, maybe even a ford? Ive had to go to the dealership to get a shroud. Anyway, thats probably the problem, along with your electric fan not coming on at high temp, or it doesnt move enough air to cool everything down fast enough. I'd get this fixed, especially if you have an automatic, it is cooled by the radiator.
Old 07-12-2007, 12:29 AM   #14
_Cody_
1993 XJ Cherokee
i dont have an electric fan on the drivers side :O
is that bad? I think the guy before me took some a/c stuff from under the hood, and could have taken that.
2002 Trans Am WS6 ~Shop Car. 396ci, LS3 heads, Turbonetics 78mm, NX express, full 10pt cage...it's fast-ish.
2000 Grand Prix GTP ~Ported, Pullied, Heads, Cam, and all that jazz.
1996 XJ Sport. 4.0/A4 Daily Driver. 4.7 stroker and 3.5" lift in the works.
_Cody_ is offline   Reply With Quote
Old 07-12-2007, 11:44 AM   #15
AZ Jeff
Yes, that's bad. ALL 4.0 XJ's NEED the electric fan to supplement the mechanical fan when driving in hot weather and/or stop and go conditions.
Get a replacement in ASAP.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Glock Forum
