Quantcast Overheat - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Overheat
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 01-28-2006, 07:17 PM   #1
Death-Mobile
Overheat
My brother just got a 94 XJ with a bad water pump. I replaced the pump for him and put a new thermostat in since the housing had a bad leaky gasket. He went and refilled the system. Now he is saying that at idle the jeep is running hot (225-230) but when he starts driving it goes down to 210. What do you think could cause this? I was thinking he may not have bled it correctly or the thermostat is bad, just seeing if anyone else had similar problems with the cooling system.
Death-Mobile is offline   Reply With Quote
Old 01-29-2006, 03:52 PM   #2
Blue XJ
1988 MJ Comanche
could be air in the system still
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline   Reply With Quote
Old 01-29-2006, 08:07 PM   #3
Shenck
Classic case for the mech fan clutch. Its like $40 at autozone. I had the same problem and a new fan clutch solved it.
------ED-----
1993 Cherokee Country, 3" AAL. with soft 8's & 31's
2007 Rubicon 6-Speed
2006 Liberty
Shenck is offline   Reply With Quote
Old 01-29-2006, 08:41 PM   #4
The Mangler
I have another question about overheating.
My friend's Jeep overheats at highway speed but cools down if he slows down to around 50. Any of you ever heard of this before?
I don't think fans would be an issue, because at highway speed you shouldn't need them. We can't figure out why it only overheats at 70mph or more.
The Mangler is offline   Reply With Quote
Old 01-29-2006, 10:34 PM   #5
Shenck
[quote=The Mangler]I have another question about overheating.
My only "guess" would be flow. Your friend seems to be getting enough flow of coolant to work at lower speeds but at higher speeds the flow isn't good enough. Could be restriction in the coolant system, water pump on it's way out, or just a "somewhat" bad radiator.
------ED-----
2006 Liberty
Old 01-29-2006, 11:06 PM   #6
mrbill
My guess would be that the lower radiator hose is collapsing (there should be a springin it). At speed if there is no spring or it has weakend, the hose will collapse due to the increased suction caused by the coolant rushing through the house. Good Luck!
89 Laredo 2-door, 4.0 I6, Auto, Rusty's 3" W/ Full Rear Spring Pack, bump stops, steering stabilizer, and steering brace. Pro Comp 31x10.5x15 on 8" black steelies. Dynomax SuperTurbo.
mrbill is offline   Reply With Quote
Old 01-29-2006, 11:10 PM   #7
The Mangler
That is definatly worth checking out. I never would have thought of that. Thanks.
Old 01-30-2006, 12:13 PM   #8
AZ Jeff
Or a bad rad that is plugged enough that the heat from higher speed running cannot be transferred out thru the fins.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 01-30-2006, 06:15 PM   #9
The Mangler
...Well, it's not the lower hose...
Wouldn't that affect low speed driving too though?
Old 01-31-2006, 06:59 AM   #10
91_Cherokee
I'm tracking down an over-heating problem in my '91 now.
Mine heasts like that...Unless I run th eclimate controls on Def, or AC....So it seems the electric fan isn;t coming on, unless the settings are on those.
In other words, double check the 12v fan, I think its supposed to come on at 220, no matter what.
[COLOR="blue"]-Billy[/COLOR]
[SIZE="1"]1991 Cheroke Laredo, 4.0 HO Auto, Black...Stock!
________
|l_|__\___\,___
l--___--_[olllllllo]
()_)' ' ''()_)---)_) [/SIZE]
91_Cherokee is offline   Reply With Quote
Old 01-31-2006, 05:34 PM   #11
JaMMin2525
1989 XJ Cherokee
i have traced my occational overheating problems to the fan clutch. But when i go to autozone to buy one they ask if mine is mechanical or electrical. I have an 89 4.0 aw4. which one is it??
Thanks!
-Jamin
1989 Cherokee XJ
| 4.0 I6 | AW4 | DPG 4" Extreme Duty Hybrid Kit | OME LT Shocks | 32X11.5 BFG AT-KO | AR 767 15x8 | NP231 | AA SYE & TW DS | Dana 44 RA Swap | 4.11 gears | B&M Trans Cooler | CSF Open Radiator Swap | WJ Brake Booster Upgrade | Teraflex Rear Disc Conversion | C4x4 Rear Bumper/Tire carrier | JCR Stge 3 Front Bumper | AJ'S Rock Sliders | Warn Diff Armor | JKS Adj. Trackbar | JKS Q. Discos | JKS LCA Skids | DPG Disco Cables | Rusty's HD Tie-Rod | Rusty's Steering Box Brace | Optima Red-Top | Silverstar Headlamps | Baja Fogs |
Where are you on Frapper??
JaMMin2525 is offline   Reply With Quote
Old 01-31-2006, 06:09 PM   #12
anony91xj
Flow problem. Could be a bad water pump, could be a plugged radiator, could be just that the coolant level is low, could be that the thermostat isn't opening all the way....
1997 VW Jetta - Daily Beater <---Totaled, seeking replacement DD
2004 GMC Envoy - Wife's Ride
anony91xj is offline   Reply With Quote
Old 01-31-2006, 06:18 PM   #13
Blake
Redefining body roll
Blake's Avatar
Thanks!
-Jamin
Mechanical.
2005 G35 Sedan
Sport Package | Mostly Stock
1999.5 Ford F250
6.8l V10 l Auto l 4WD l 4" Spring Lift | 4.30 Gears | 35" Treadwright MT/R's
1987 Mercedes 300D Turbo
Stock | European Headlight Conversion!!1!
Blake is offline   Reply With Quote
Old 01-31-2006, 06:57 PM   #14
YJinSD
Mine was doing the same thing, and it was the radiator. That didn't bring it back completely, but it is below redline, I'm thinking a regear will put it right. It does rev pretty hard at 70.
YJinSD is offline   Reply With Quote
Old 01-31-2006, 09:21 PM   #15
AZ Jeff
Engine generates more heat at higher speeds, thus needing to dump more heat thru the rad.
AZ-Jeff
Glock Forum
