Overflow tank boiling over. - JeepForum.com
post #1 of 13 Old 01-03-2009, 03:26 PM Thread Starter
MSH5337
MSH5337's Avatar
Well, I just got my Waggy back after letting my brother-in-law (ex brother-in-law now) use it for a few months (will NEVER do that again). I'm now having a problem with it. After idleing for a few minutes, the overflow starts boiling over. The temp gauge isnt reading hot though. What could this be? Thermostat? Backed up radiator? I'm planning on flushing the system tomorrow. Any other ideas?
2001 Amber Fire TJ
1989 Wagoneer Limited. 4X4
MSH5337 is offline
post #2 of 13 Old 01-03-2009, 03:35 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Could be a number of things. could be the thermostat, go ahead and change it when you do the flush. but you need to make sure all the air is out of the system, and that there are no leaks. the closed system needs to be pressurized.
xjfever is offline
post #3 of 13 Old 01-03-2009, 03:54 PM
tangofox007
Every time I had that happen, the problem was with the bottle or the cap.
tangofox007 is offline
post #4 of 13 Old 01-03-2009, 05:46 PM
ech0sh4y
2008 WK
Sounds like a bad radiator cap to me. Might was to just splurge and get a new one for $10!
~ Brian
2008 WK Overland CRD
ech0sh4y is offline
post #5 of 13 Old 01-03-2009, 05:52 PM
tangofox007
There is no radiator cap on an '89.
post #6 of 13 Old 01-03-2009, 06:00 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
If it does not read hot, most of the coolant is likey gone. If the cap on the resovoir bottle is bad, the coolant will boil (it is just like the cap for the radiator in an "open" cooling system--it is pressurized).
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #7 of 13 Old 01-03-2009, 06:01 PM
Saudade
1988 XJ Cherokee
It's still the "cap". There's no "overflow" bottle on the closed system.
Saudade is offline
post #8 of 13 Old 01-03-2009, 06:05 PM
ech0sh4y
2008 WK
My bad... sorry for the misunderstanding
~ Brian
ech0sh4y is offline
post #9 of 13 Old 01-03-2009, 08:15 PM
hennigm4
1987 XJ Cherokee
Replace the cap or the bottle first, burp the system of all air, there is a technique for the closed systems.
hennigm4 is offline
post #10 of 13 Old 01-04-2009, 05:13 PM Thread Starter
MSH5337
MSH5337's Avatar
Well, I didn't get around to flushing the system today, but I did replace the bottle and cap. Didn't help.
2001 Amber Fire TJ
MSH5337 is offline
post #11 of 13 Old 01-04-2009, 06:16 PM
AZ Jeff
2014 JK Wrangler
Did you "burp" using the recommended approach? The closed systems are VERY sensitive to proper air removal procedures.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #12 of 13 Old 01-04-2009, 07:01 PM Thread Starter
MSH5337
MSH5337's Avatar
No, I haven't burped the system yet. What exactly is the "recomended approach" though? I'm not too familiar with the closed systems, and appreciate all the help.
2001 Amber Fire TJ
MSH5337 is offline
post #13 of 13 Old 01-08-2009, 05:28 PM Thread Starter
MSH5337
MSH5337's Avatar
Problem solved! It was the thermostat. Thanks for all the help, you guys are great!
2001 Amber Fire TJ
MSH5337 is offline
1987 Cherokee Overflow tank Skaf XJ Cherokee Technical Forum 16 05-12-2013 05:35 PM
Coolant pouring out of my overflow tank jwiowa XJ Cherokee Technical Forum 7 12-19-2009 10:27 AM
Boiling Over wbacon XJ Cherokee Technical Forum 5 01-07-2008 04:45 PM
help with 89 overflow tank leak eas020223 XJ Cherokee Technical Forum 4 04-27-2005 11:16 AM
how to fix leaking overflow tank? eas020223 XJ Cherokee Technical Forum 4 02-06-2005 01:36 PM
