Opinions on tire width. - JeepForum.com
post #1 of 7 Old 04-10-2009, 06:02 PM Thread Starter
cheesehead
This is more of an opinion than technical question. I can fit either 33x10.50x15s or 32x11.50x15s on my XJ. I like wheeling in Moab. I also do trails in the mountains with loose rock and some occasional mud. What do ya say. Go for the 33's to gain ground clearance or go with the 32's to gain width, footprint and floatation?? Too expensive to get both...
cheesehead is offline
post #2 of 7 Old 04-10-2009, 06:37 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would go with the 33's, being narrower will get you farther in the mud, and you already have the correct gearing for them.
xjfever is offline
post #3 of 7 Old 04-10-2009, 06:37 PM
Kpat
I would definitely go with the 33X10.5 for that extra clearance.
2000 XJ 4" 33's... TJ on 1 tons and 40's after Afghanistan!
Kpat is offline
post #4 of 7 Old 04-10-2009, 08:05 PM
2drx4
1990 XJ Cherokee
Wait, save, get some 33x12.5s...
Otherwise you're just going to wish you had later.
2drx4 is offline
post #5 of 7 Old 04-10-2009, 08:23 PM
Magus2727
1995 XJ Cherokee
I am saving up my Plasma money donations for 33" x 12.5"... For your wheeling I would go with the wider... if you want it to do well in the snow go for the narrow...
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline
post #6 of 7 Old 04-10-2009, 08:24 PM Thread Starter
cheesehead
I wish I could fit 33x12.50's. I can find them on Craigs list every week.. Unfortunately the width will not clear on my front fenders like the 10.50's do. Just trying to hold off on doing more angle grinder trimming for now...
post #7 of 7 Old 04-10-2009, 08:30 PM
conrasm
conrasm's Avatar
I had 32's for a while and didn't have much trouble with clearance without trimming. I had bumpstops in the front to keep the tires out of the fenders. I went to 10.5x34 and they actually tuck in the fenders with the 4" BS rims. I did trim some, just the rim of the flare in the rear and about 2" of the fender in the front. I'm glad I didn't go with 12.5 width. PA has horrible fender flare laws (no more than 3") and the local cops like to pully people over for little things like that, especially if your tires stick out past the flare.
the 33 will only get you about 1/2" of axle clearance, so not much difference.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
max tire width dirt4900 XJ Cherokee Technical Forum 8 05-28-2009 09:38 PM
Tire height width typer1122 XJ Cherokee Technical Forum 1 05-10-2009 06:41 PM
tire width?? joeyschribar XJ Cherokee Technical Forum 7 02-16-2008 08:14 PM
tire width ramone XJ Cherokee Technical Forum 7 09-18-2006 07:15 PM
Rim Width vs Tire Size Blue XJ XJ Cherokee Technical Forum 5 05-14-2006 10:07 PM
