Opinions on replacing AW4 transmission fluid - Page 5 - JeepForum.com
post #61 of 65 Old 08-31-2012, 07:04 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Originally Posted by roblaza View Post
OKAY, i'm bringing this back to life. I've read the 4 pages and haven't really come to a conclusion. My XJ has 192,000km on it and it looks as if it's been a long time since the last fluid change as it's just about brown. Should I change it out?? Should I leave it? Should I drain the pan and fill it, drive it, drain, fill drive, drain fill drive? I need some serious advice on this topic. It is shifting great right now, but do I want to keep the old crap fluid in there??
The answer to this question is easy. You do NOT want to leave old brown transmission fluid in there!! And I will argue with anybody that says you should. Fluid wears out. And it needs to be replaced. Period.
I am a big fan of the technique of draining what is in the pan, refilling with Dex/Merc III (not ATF+4), running for a couple hundred miles, then repeating until the fluid STAYS a nice red color.
This is an inexpensive and safe way to maximize the life of your abused AW4 transmission.
And changing or cleaning the filter when you reach a consistent RED color might not be a bad idea.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #62 of 65 Old 08-31-2012, 07:17 PM
roblaza
THANK YOU. I appreciate the input. I'll get on the trans ASAP. I had the oil changed tonight and while it was up, checked the t-case and it was virtually dry. I'm amazed that the 4x4 still works and isn't completely shot. (I just bought the truck...today is the first time it was driven since I obtained it.) The T-case was cleaned and filled with new fluid and the oil/filter was changed. Trans and diff's are next on the list.
roblaza is offline
post #63 of 65 Old 11-06-2012, 03:35 PM
ideliver
1996 FSJ Cherokee
ok I am new to this stuff. I don't even know if I am posting in the right spot. I have a 96 jeep cherokee. it is a right hand drive and a work horse. but I am having trouble with the tanismission. had it rebuilt about 10 months ago. My mechanic has went through it twice now and it starts out fine then when the weather is cooler it will not go into reverse for about 5 min. it works great most of the time but then starts slipping quits and runs fine... He put synthetic fluid in it. Could this be causing the problem?????
ideliver is offline
post #64 of 65 Old 11-06-2012, 03:49 PM
tjwalker
tjwalker's Avatar
Your post is related to fluid, but I'd highly recommend that you start a NEW thread.
You will get more accurate replies and they will be replies that are related only to your issue.
tjwalker is offline
post #65 of 65 Old 06-17-2013, 12:00 PM
RyanXJweisheit
the detergents in fresh ATF also causes problems after a flush or change. It cleans an loosens dirt and **** built up from the old fluid and debris cause a failure
RyanXJweisheit is offline
Replacing front & rear differential fluid? Mee_Too XJ Cherokee Technical Forum 38 02-12-2013 06:08 PM
replacing front diff fluid Cherokee98_4x4 XJ Cherokee Technical Forum 3 11-18-2009 02:32 PM
help Replacing Auto tranny filter and fluid motu1983 XJ Cherokee Technical Forum 14 10-06-2007 05:51 PM
Automatic Transmission fluid change, and Transfer Case fluid change questions. MageXX9 XJ Cherokee Technical Forum 4 04-28-2007 05:08 PM
Replacing transmission filter/fluid fourlow XJ Cherokee Technical Forum 8 02-18-2004 03:24 AM
