Opinions on replacing AW4 transmission fluid - Page 4 - JeepForum.com
post #46 of 65 Old 10-17-2010, 08:09 AM
tangofox007
Originally Posted by Weebur View Post
You'll be fine using either Dextron III/Mercon or ATF+4 (which Chrysler now recommends).
There are a number of reports on this forum that suggest ATF+4 might not be so "fine."
tangofox007 is offline
post #47 of 65 Old 10-17-2010, 11:07 AM
Weebur
1997 XJ Cherokee
I know that there are very strong feelings about this subject but I'll still have to stand with the engineers. From the 2007 bulletin (NUMBER: 21-014-07
BENEFITS
^ Better anti-wear properties
^ Improved rust/corrosion prevention
^ Controls oxidation
^ Eliminates deposits
^ Controls friction
^ Retains anti-foaming properties
^ Superior properties for low temperature operation
FLUID COLOR
Mopar ATF+4(R) has exceptional durability. However, the red dye used in ATF+4(R) is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4(R) also has a unique odor that may change with age. With ATF+4(R) fluid, color and odor are no longer indicators of fluid condition and do not necessarily support a fluid change.
Weebur is offline
post #48 of 65 Old 10-17-2010, 12:07 PM
tangofox007
I know that there are very strong feelings about this subject but I'll still have to stand with the engineers. From the 2007 bulletin (NUMBER: 21-014-07)
Do you have any idea why "the engineers" don't recommend ATF+4 in the XJ models prior to 1989? Is there something special about the pre-1989 AW-4 transmissions? Or did "the engineers" get confused?
post #49 of 65 Old 10-17-2010, 01:11 PM
Weebur
1997 XJ Cherokee
[QUOTE=tangofox007;10295584]Do you have any idea why "the engineers" don't recommend ATF+4 in the XJ models prior to 1989? Is there something special about the pre-1989 AW-4 transmissions? Or did "the engineers" get confused?[/QUOTE
I have no idea why they didn't include the '87 and '88 model years...was there a design change in '89...don't know. I do know that they will issue FSB's based on warranty and other dealer repair feedback; maybe that's why they did it...then again there have been some "Black Helicopters" around lately.
I'm done here. I'm changing my power steering pump (from O'Reillys) for the third time in six weeks.
Weebur is offline
post #50 of 65 Old 10-17-2010, 01:28 PM
tangofox007
Are you using ATF+4 in your power steering pump? That's what the later model Jeeps use.
post #51 of 65 Old 10-17-2010, 05:18 PM
Weebur
1997 XJ Cherokee
Just finished...finally got a good (quiet) one. ATF+4...nope, the FSM says not to use ATF in this pump.
Weebur is offline
post #52 of 65 Old 04-22-2012, 03:22 PM
BUSA
How many quartz does the 99 xj tranny hold want to change mine THANKZ..................
BUSA is offline
post #53 of 65 Old 04-22-2012, 04:21 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
If you only drain what is in the pan, it will take between 3-4 quarts to refill. A whole lot more if you're replacing every drop in the transmission, torque converter and pan.
Be darn sure not to overfill when you refill. A little fluid goes a long ways on that dipstick. Final additions should be done with a hot engine, fully exercised transmission, level surface.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #54 of 65 Old 04-22-2012, 04:23 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
IIRC, 3 in the pan and like 8 in the transmission.
EDIT:
The 99 FSM indicates that the approximate refill capacity for the AW-4 is 8.0 liters (16.9 pints), i.e. 8.5 quarts. This would be completely dry including the torque converter.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #55 of 65 Old 04-25-2012, 10:41 PM
BUSA
[QUOTE="tjwalker"]
Be darn sure not to overfill when you refill. A little fluid goes a long ways on that dipstick. Final additions should be done with a hot engine, fully exercised transmission, level surface.[/QUOTE. What would you perfer doin the filter or just drain and fill Thankz jeeperz...........
BUSA is offline
post #56 of 65 Old 04-26-2012, 05:20 AM
tjwalker
tjwalker's Avatar
Drain and fill is usually fine unless you are experiencing systems or unless fluid changes have been ignored....ie: fluid is dark and/or you don't know history of maintenance. Then it's not a bad idea to drop the pan and clean or replace the filter (basically a screen).
tjwalker is offline
post #57 of 65 Old 04-26-2012, 10:10 AM
BUSA
THe fluid is still red and have maintance paperz on everything from the guy.....
BUSA is offline
post #58 of 65 Old 04-26-2012, 06:53 PM
tjwalker
tjwalker's Avatar
THe fluid is still red and have maintance paperz on everything from the guy i bought it from now have to do front axle sealz is it very hard whatz involved thankz........
Start a new thread. The repair you are asking about is not related to this one. It gets too confusing to stack one type of repair on another.
tjwalker is offline
post #59 of 65 Old 04-26-2012, 09:46 PM
Paradise XJ
1988 MJ Comanche
Iz your "S" key brokez??
Takes away from the intelligence in your post if you still spell like a third grader.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #60 of 65 Old 08-31-2012, 07:52 PM
roblaza
OKAY, i'm bringing this back to life. I've read the 4 pages and haven't really come to a conclusion. My XJ has 192,000km on it and it looks as if it's been a long time since the last fluid change as it's just about brown. Should I change it out?? Should I leave it? Should I drain the pan and fill it, drive it, drain, fill drive, drain fill drive? I need some serious advice on this topic. It is shifting great right now, but do I want to keep the old crap fluid in there??
roblaza is offline
Replacing front & rear differential fluid? Mee_Too XJ Cherokee Technical Forum 38 02-12-2013 07:08 PM
replacing front diff fluid Cherokee98_4x4 XJ Cherokee Technical Forum 3 11-18-2009 03:32 PM
help Replacing Auto tranny filter and fluid motu1983 XJ Cherokee Technical Forum 14 10-06-2007 06:51 PM
Automatic Transmission fluid change, and Transfer Case fluid change questions. MageXX9 XJ Cherokee Technical Forum 4 04-28-2007 06:08 PM
Replacing transmission filter/fluid fourlow XJ Cherokee Technical Forum 8 02-18-2004 04:24 AM
